Bob, is that the Canton 22-597? Did the bolt reach and thread straight into the block, or did you need a union fitting? Thanks.
Yes it is a 22-597. It threaded right to a 1.5x20 nipple in the block.
I did grind on the corners of the canton block to get the rotation I wanted.
http://thefactoryfiveforum.com/attac...0&d=1472427261
