Should the tranny be dry? Fluid runs out of tail shaft when angled
Unless you are using a cap plug to prevent leakage then installing it dry is way less messy and you don't have to go back and top it off.
Sorry, cap plug?
Slips through the rear tranny seal, and over the splined shaft, to prevent fluid leaking..
https://www.amazon.com/Lisle-23400-T...QDHFP70VK0SZ9X
You should have free play, if not something is binding.
I mean, lever moves freely until the throw out bearing engages the clutch fingers, then I can't get the lever to move the fingers at all.
