well maybe not a lambo wheel the new charger wheels are hot and the speedometer most of them will fit from most cars just a matter of cutting out the out line and sticking in as for the radio thats all plug n play is how it comes maybe a little fiberglass work all depends on what u use. its just a thought on what mine is going to look like . something a little more updated than that kit car interior look i didnt modify nothing in the renderiing as in dash or anything just the radio and gauges which like i said before depending on what u use maybe will fit maybe a little fiberglass work nothing major
NYCarStars
It will be MAJOR. It will take a complete custom fabrication of the console and IP dash. Primarily because of the scale. The items in your rendering are larger than the areas you've placed them on. I'm not home to measure, but I think the width of the gauge pad is about 13" and the console is just over 9" just below the vents.
It could be done. Just don't expect it to be "a little fiberglass work".
R/s
Vidal
CURRENT STATUS: Interior Rework and Bodywork.
GenII GTM #331. Delivered (23/9/10)
BUILD LOG AND WEBSITE:
http://gtmbuild.weebly.com/ .
