13
25
Oil filling crankcase when 818 not used for more than a couple months.
My 818 has an Aviaid dry sump system. It has 2 external scavenge pumps and uses the OEM oil pump.
Twice while the car sat without starting the engine for 3+ months, the oil from the tank filled the crankcase. This last time, I believe it was high enough in the block to get past the piston rings and fill the exhaust manifold. When starting, the car smoked badly for 5 to 10 minutes.
Has anyone else seen this with a dry sump system on a flat engine?
Bob_n_Cincy
I was just about to post a similar issue. I did a first start two months ago, then let it sit, it's been seeping oil on the floor from what I think is the cam seals. The sump tank is very low now, but I bet the cylinders are filled with oil, too. I think this is just an inherent problem with dry sump systems. After talking with some other people, it seems dry sumps will eventually do this the only option is to put a shut off valve in the feed line (I don't know if I like this idea) or to drain the oil if you know it will be sitting for a bit (Apparently, a lot of race teams do this).
