Easy stuff first..."sputtering & coughing with no throttle response"---check fuel pressure. If that's good be sure that the mass air meter wiring is intact. Next suspicion would be TFI module.
Good luck,
Good luck,
Mark
Welcome to the club, but I agree, better driving it than have it sitting in the garage. Mine happened when the ECU for the Powerjection died. Hope you get it sorted out soon
