I don't know if I have a Vintage Air AC/Heater. Nothing on it says that. It says Siroco? I have already drilled the fire wall where the instructions said not down below. Here are some pictures I took explaining to FFR Tec what the problem was. 100_2313.JPG 100_2314.JPG 100_2315.JPG 100_2316.JPG 100_2319.JPG
You can see that the fitting for the AC is blocked by the fan housing. Does the unit for the gen 1 say Vintage Air?
Tec was no help. They called the evaporator the condenser and vice versa.
I will run the car without heat and A/C until if moving the evaporator over left fixes it or I can get some good answers.
