25th Anniversary #9772
Helicopter Wrench-Bender
Check out post #19 by Kp on this thread. Looks like he used a "?" diameter forstner bit/hole cutting bit and cut out the material and then re-powder coated in red.
"Gravity, It's The Law"
ChopperJustin
ah yes i see now, I will probably try my hole saw ~1 1/8th and give it a try...
trimmed with a 1 1/4" hole saw, worked great!
still had to trim the lower portion of the pedalbox mount because it conflicts with the steering bearing when you pull it inside the footbox
https://thefactoryfiveforum.com/show...l=1#post412193
I unstalled the Whitby PB kit in my Non-donoR MK4. The only thing i changed was I used a master cyl from Speedway to get the correct ratio, woks great. The holes in the frame mounted up to the PB unit just fine.
Baghdad Bob
mcwho
what was the different using the speedway master from the bendix master that whiby provides?
what was your pedal distance from the back of the footbox?
With the firewall forwad kit I didn't have enough clearance or verticle room to mount the emote resevoi units. The one I used from Speedway has an integral snap on lot, speedway pat link is here. 1 Bore
https://www.speedwaymotors.com/Alumi...ore,50598.html
I have about 4" of clearance from the pedal to the alum panel.
Baghdad Bob
