I have the current FFR trunk hinges and struts with the Breeze cubby mod. It does work, but there are some drawbacks:
- If you have the cubby you need to cut large holes in the back wall as the struts pivot up when open and down when closed. This can also cause things stored in the cubby to get pinched when the lid is closed. The large holes allow moisture to be pushed through from the trunk when driving in rain and cold air when driving with a top in chilly weather.
- The struts interfere somewhat with storage, both in the trunk and cubby area.
- If the struts are undersized they will fail to hold the trunk open, or if they are oversized they'll cause an excessive gap in the trunk lid at the back deck of the body.
I'm not saying they aren't a good option for most, but I'm not convinced it's better than just using a good old-fashion prop rod and hidden hinges for my uses.
Bradley
