I agree and believed them when they said it had never happened before. Like most they immediately assumed that I wasn't putting them together correctly. What the actual issue was the PTFE liner was slightly undersized, so the crimp wasn't working correctly. They were shocked when theirs leaked too.
Point being that any brand can be an issue, which is why one should ALWAYS perform a pressure test @ at least 500psi on PTFE steel braided lines. You never know for sure until you test.
On pressure testing, how does one pump 500PSI into a line? The electric tire pump I have only goes up to 125PSI max.
Mk4 Roadster: Gen 3 Coyote, IRS, T56 Magnum. Build thread here.
The pressure used to test a hose assembly would depend on the application pressure and of course, don't exceed the working pressure rating of the hose & fittings used. A brake hose may require a greater pressure than a low pressure fuel line. For low pressure braided SS AN style fuel lines (carb or EFI) a typical home use style air compressor provides plenty of test pressure. I like to cap one end and adapt a short piece of polyflow tube to the other and attach that to an air hose. A bucket of water will give you instant results.
If you want to make your own brake hoses (not recommended) or make fuel lines for direct injection systems, you can either purchase a hydraulic pump or use an old master cylinder to rig a home grown high pressure tester. A hyd power pack pump can also be adapted -- you just have to be creative.
Looks like I did my pressure test with air incorrect, went to 65 psi for 10 minutes and no air leaks. The EFi system I am using runs at 58psi. Have not had any issues with fuel leakage to this point after 2700 miles on the car now. Knock on wood hopefully my luck continues.
