Great project. Keep us posted.
I am going to assume that you are building a roadster. I am not tall at all (5'10"), and with the seat bolted to the floor, I am almost to tall for the coupe.
Yes. I'm planning on the soft top only. I haven't driven the 33 before but I've looked them over close at SEMA a few times. Pedal spacing and footbox room will be easy since it won't have the big trans tunnel. I also ordered the tilt column. I'm right at 6' tall and based on the checking around I did it seems like it will be fine. I do want adjustable seats though - hopefully I can pull that off.
I've driven a MK4. It was a little tight but comfortable enough.
Sounds like you have definitely done your homework. I was also thinking that having the rear-motor and batteries under the floor will let you skip the trans tunnel and give you more foot room, even though you don't have a clutch pedal to worry about, I know there isn't a lot of room there.
Are you going to run AC? Looked into that yet? With more hybrids out there and electric compressors I am hoping its not too hard to set something up like that.
And yay, more pics!
