I separated the body from the frame and made this raised table on wheels for it to sit on. That way I can store it over top of the frame and wheel it out of the way when I need to work.
I ordered my fame bare as I wanted something different than black.
So I've taken it upon myself to clean up any sharp edges and weld spatter as the first step before powdercoating.
One positive outcome of this is that I'm getting a good understanding of the frame layout and a real appreciation for the workmanship that goes into them.
Beautiful.
Apologies for the surface rust, an unavoidable consequence of the long, wet drive home and monsoon season here in southern Ontario.
Note that I've been using what are known as "surface conditioning" discs for the clean-up. If you never used them, they're like scotchbrite pads on steroids.
Earl
I think that's the first time I've seen the Speedstar body in the raw. I didn't know the entire cowl was different! I though just the cowl where it meets the windshield frame. Which means the back edge of the hood and side covers is different too. this body will probably not look good without side covers.
Guess I need to go look at the Speedstar gallery again...
Here is my Speedstar.
