Likes Likes:  3
Results 1 to 40 of 99
Thread: the dreaded throttle control error codes
Hybrid View
    Rick, do you have have a actual wire from battery negative to engine block? Or are you going through the chassis?
    Bolton, Ontario, Canada
    My ground lead uses the frame. My reasoning is:
    1) Millions of production cars do it this way and it works; including Subaru I imagine (though my car came with the donor stuff already stripped out so I don't know for sure).
    2) The car starts fine which means the ground conducts a couple hundred amps without issue.
    3) The ground lead at the battery is short and goes onto the frame; clean connection. There is a robust lead from the engine block to the frame at the rear.
    4) If it was a ground momentarily losing contact, would it cause this exact symptom every time? Honestly, I have no idea.
    I could run a booster cable clamped on the battery and the other end onto the engine, if I can figure a way to do that while leaving the car drivable; hood and rear deck lid partially open.
