But. .. Thinking it a little over the effective piston area should be doubled because fluid don't compress or stretch, so there will be equal force pulling and pushing at the same time? That should effectively double force capacity at given pressure? That means that to maintain the needed force the pressure can be reduced to 1015psi for the same result, and there will be a lot of headroom for spikes?
