Thread: Burnt Wire
    Burnt Wire
    Can anyone help me identify what this burnt wire does? It's connected to the battery cut off switch in between the drivers seat. This photo is from underneath.
    Many thanks
    JML
    that's called a fusible link. you had a large short that caused it to burn. I would replace it with another length of the same wire. I don't know what it powers. Does the car run without it?
    Senior Member mjazzka's Avatar
    Jun 2014
    Katy, TX
    Just going by what I've seen in my wiring (it looks like it splits into a few wires in the bottom left corner), that looks like it might be the cable that goes to your alternator
    Michael
    Coupe #675 "Eloise"
    10/14/14 Coupe Ordered - 1/29/15 Coupe Delivered - 5/1/16 First Start
    Build Thread - Flickr
    Quote Originally Posted by mjazzka View Post
    many thanks i have checked and the wire goes nowhere it must have been replaced at some point and the old wire left in there
    JML
    Senior Member CJBergquist's Avatar
    Palo Alto, CA
    If it goes nowhere you should pull it now so in the future there is no confusion what the wire is/was for.
    If it's too LOUD....you're too OLD!!
    Build Site >> http://www.flickr.com/photos/51103049@N00/collections/
    FFR#0441CP Complete Coupe kit, IRS, T-5, 392ci 351W, Webers, Delivered 4/29/09
    Jun 2014
    Katy, TX
    Quote Originally Posted by JML View Post
    JML
    Mystery solved then, I hope that is indeed the case!
    Michael
    Coupe #675 "Eloise"
    Quote Originally Posted by CJBergquist View Post
    In addition you don't want that wire shorting out against any metal nearby! It's a hazard and needs to be removed from the switch. I'd also trace the other end and delete it from the harness if it truly is "disconnected".
    Good Advice i will remove the wire and try and trace where it may have come from on the harness
    many thanks
    JML
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    That's a bit scary. What David and others said, get it out of there.
    Kyle
