Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 198
Thread: York's 818s
  1. #121
    Finally!!! Another 6cyl!!
    I thought the H6 was "unboostable" due to weird crank or rod angle and lack of aftermarket parts, was that more for the 3.6?
    Ok you got H6 3.0 or 3.6?
    How much boost and power you could get out of it (boosted)?
  2. #122
    San Diego Ca 92106
    Both have been turbo'd, on the Haltec website There's a link to an ez36 build.
  3. #123
    Senior Member alpine227's Avatar
    maine
    The 3.6 has offset rods but has been boosted low pressure the most famous being the mighty car mods Gramps build. Some obstacles are the small rods, 10.7:1 compression and open deck block. Wayne pulled 320ish at 8psi stock block (larger injectors). With rods, pistons, sleeves valves and springs Perrin got 600 around 20psi if I recall. I recall seeing a twin ez with 1400ish but it had closed deck block built heads pistons rods crank and twin snails and a horrid torque curve
  4. #124
    maine
    Welcome to the H6 club! There are only a few of us, but are ranks are growing. I hope to have mine started by the end of the month.
    What are you running for exhaust?
    I am running the 1st gen ez30 single port. I am using a crossover pipe similar to the ej20 had to relocate a few pesky coolant lines still fabricating the rest of it. The uppipe is going to pass near stock turbo location hook down go through hiflow cat, flow through muffler. Winter time will add turbo flange, and ewg plumbing.
  5. #125
    maine
    I scored a H6 outback for $300 had a blown transmission sold a few hundred of parts and should get some more from the scrap yard. So I got paid for this engine! Feels weird making money on new parts... May even make enough for the new injectors.
  6. #126
    maine
    https://youtu.be/Ow3xa8jpU5c
    First start of the H6, I need to adjust idle settings. Also not good for the tinnitus without exhaust on.
  7. #127
    San Diego Ca 92106
    Congrats on the first start! What are your plans for the exhaust?
  8. #128
    maine
    Well my first thought was to use the header I had from my wrx that was h6 swapped but clearance issues with chassis and coolant lines I have moved to to disturbingly tight bends up between the heads and motor mounts to a 2 into 1 cat 2 180 degree bends to a flow through muffler out the back. This is because I have all the pipe on hand and I am currently executing operation get this thing back on the road before the white stuff falls from the sky. The winter I will build a crossover and uppipe similar to Wayne's for the gt35 turbo setup with 321 stainless and someone who welds better than me.
  9. #129
    Awesome 1st start! It looks monstrous when you give it some gas!!
    321 stainless? Never heard of that metal type, what's so special about it?
  10. #130
    maine
    321 is similar to 304 but with titanium in it. It is more resistant to cracking due to high tempatures than 304.
  11. #131
    Is there enough titanium in it to change the exhaust note?
  12. #132
    maine
    I don't know if it changes the tone, however fun lesson learned today don't pick up with bare hands the piece you just finished welding 2 seconds prior, probably shouldn't be in the garage today have a 102 fever not really running on all cylinders. The only things my kids share is brocolli and germs.
  13. #133
    maine
    https://youtu.be/8qbavtcQxvs
    No more boxer rumble. Ignore my out of date virus protection. Still needs a tune but i don't need hearing protection now!
  14. #134
    How did you change the usual sound like that? Amazing!
  15. #135
    maine
    I ran the oem 2:1 cat and a flow through muffler. The induction noise is probably louder than the exhaust ATM.
  16. #136
    maine
    https://youtu.be/fqH6twsUJMU
    Definitely enjoying the extra two cylinders it does seem to run out of steam in the top end though might need some more manifold pressure ��
  17. #137
    It has some kind of a racing sound in there, love it! Maybe a little Porsche-like or something... Not the big 3.6 Porsches but say the earlier ones.
  18. #138
    maine
    The car sounds more like it looks in Comparison to the H4. New issue is the outback cluster is too wide for the guage pod from ffr and ms3 can't scale the tach output for 6cyl on a 4cyl tach it can only double it or half it. Possible solution is make an overlay for the guage face calibrated for the 6cyl my observing needle location at various RPMs confirmed on tuning software. Or use a pic controller to intercept and scale the signal (not sure how much delay this would cause I am guessing it's a square wave output)
  19. #139
    Isn't the RPM signal pulse-based? Like 2 pulses per second, 4, etc... If so, you could convert the 6cyl's output pulses to whatever the tach is expecting, assuming such a conversion is possible.
  20. #140
    Quote Originally Posted by alpine227 View Post
    http://www.dakotadigital.com/index.c...rod/prd127.htm
  21. #141
    Syracuse, NY
    I do not know what firmware version you are using with your MS3 but the latest version does have variable scaling built into the tach output.
    Update your firmware and your tach problem is solved for free!
    MK3.1 Roadster completed 2011
  22. #142
    maine
    I am about two behind, thank you for the great news!
  23. #143
    maine
    A few mouse clicks and I have an accurate tach thanks again.
  24. #144
    Bowling Green, KY
    Your H6 sounds great.
  25. #145
    maine
    Thank you, I am happy with the way it turned out. My inner teenager is pouting because there is no bov sound though.
  26. #146
    Nepa
    you ran stock stock headers? any pics of the exhaust
  27. #147
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Sounds great!!! Nice work.
  28. #148
    maine
    Quote Originally Posted by Samiam1017 View Post
    The stock headers, were hacked up and some obsurdidly poor flowing tight turns were made to clear the chassis and suspension. The primarys bolt up to the factory 2:1 cat than into a 3" flow through muffler out the back. I will take some pictures tomorrow and upload them for you. It's honestly quickly done poorly planned exhaust setup with the goal of getting some more miles on it before the snow starts falling. Flanges weld els and bits are on order for this winter project of adding boost.
  29. #149
    can you fit the raptor header? i know they make huge gains.
    http://raptorsc.com.au/subaru/subaru...n-ez30-header/
  30. #150
    San Diego Ca 92106
    The Raptor headers don't fit. I have a pair. I haven't decided whether to cut them or to start from scratch.
  31. #151
    maine
    I went the easier route with a first gen single port exhaust. The headers likely interfer with the chassis as the stockers did. My next exhaust will terminate with a t3 flange for a turbo because if it isn't broke I haven't turboed it yet.....
  32. #152
    how much boost are you planning on running? a tuned intake long tube header and exhaust might be good for almost 45 hp.
    might not be worth the added expense, complication, and weight to go turbo if you don't plan on really boosting it.
    good to know. easier to cut the frame or the header?
  33. #153
    San Diego Ca 92106
    The header. The raptor headers would have to go thru the part of the frame that the engine mounts to. I'm pretty sure I'm going to route it the way that John (hobby racer) is going to, except that I'll be going out the back instead of through the humps like he is planning.
  34. #154
    maine
    Expense is pretty low turbo and ewg is on the shelf. Will turn a npple for oil return and weld to valve cover and have parts for oil feed and coolant lines on hand as well. The only cost will be a t3 flange and materials for manifold and uppipe.
  35. #155
    maine
    I was playing around with a spare set of first gen ez30 injectors. They are air assist and have a very unusual pintle caps. They flow around 230cc/min. I removed the cap and noticed they have a similar disk covering the output side as wrx injectors. I decapped the disk reassembled the injectors and did a crude flow test using a graduated cylinder fuel pressure regulator, walbro external pump and a push button to simulate to energize the injector and a tee and fuel line for a make shift rail. I ran the pump to prime the fuel rail and energized the injector to similate 100% duty cycle and ran the test for 30 seconds. I conducted the test on 7 spare injectors I had 6 out of 7 produced between 320 and 330 cc per the 30 seconds and one odd ball ran 290 cc. I checked the odd ball a second time with the same results. Spray pattern was a bit dodgy but the factory pattern wasn't great either.
  36. #156
    maine
    https://youtu.be/-jLUemFSWqE
    Closed course professional driver.
    Are there any oem or after market ring and pinon gears that are a bit longer? Just kinda noise at cruise and have to shift twice for 60mph.
  37. #157
    maine
    I replaced the factory oil "cooler" with an external air to oil cooler mounter in the driver's side scoop.i need to make some ducting for it still. The 198k motor is consuming a little bit of coolant so a rebuild is in order this winter before she see some positive pressure.
  38. #158
    are you running the 5mt? what final drive do you currently have? there are 4 oem ratios made.
    https://www.flatironstuning.com/p-26...-gear-set.aspx
  39. #159
    maine
    Should be 3.9 I found this a few days ago its not a huge change but does get me to just over 60 in second. Added to Christmas list with LSD.
  40. #160
    maine
    Had a little flat 6 therapy today before it all gets pulled for a rebuild and boost. Melts the stress away!
