I have a light weight flywheel and crank pulley. I upped the idle speeds across the board with RomRaider and ECUflash. It helped a bunch, but it is still "iffy" and I get occasional stalls.
I have no air leaks etc. (from pressure tests of the inlet tract.). So I'm going to change to stock flywheel and damped crank pulley. Rapid engine accel. is not as important to me as not worrying about some heel and toe to avoid stalling.
