Results 1 to 40 of 80
Thread: Bump steer
Hybrid View
    Kirkland, WA
    Quote Originally Posted by fastzrex View Post
    What method do you use to adjust the front bump steer? Are you adjusting the rack height through shims/bushings or spacing the tie rod end at the steering arm? If you are adjusting the tie rod end at the steering arm, did you replace the end links with rod ends? Thanks for your insight!
    Adjusting the steering arm, you will need to replace the rod ends, adjusters/sleeves and stud/shaft, I have documented the parts that I used in this tread.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Senior Member fastzrex's Avatar
    Oklahoma City
    Thanks for the info! Are you referencing your build thread for the bump steer components?
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
    Oklahoma City
    Tony, thanks for your work in finding these parts and process. I found the following in your build thread and posting again so I can find them in the future and for other's reference:
    Here are the parts I sourced out to get a bump steer kit that would work, height wise and adjustable
    http://www.speedwaymotors.com/Adjust...=91636055PINTO
    http://www.speedwaymotors.com/Search...+Inch+x+1+Inch
    http://www.racecraft.com/index.php?m...result&search_ in_description=0&keyword=RC21083&x=21&y=8
    http://steinjager.com/shop/index.php...earch=J0041201
    ~ Mark
    Saline, Mi
    Could not get the links to work.
    Kirkland, WA
    Quote Originally Posted by frankc5r View Post
    The links in my original post #661 work, http://thefactoryfiveforum.com/showt...attle-WA/page3
    Tony Nadalin
    Oklahoma City
    Yep, I screwed up, copied the text rather than the actual underlying link address; and then did not test. I will do better next time!
    ~ Mark
