Page 4 of 27 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 1063
Thread: And it begins..."The Flash" Build Thread
  1. #121
    Aug 2011
    Logan, UT
    Had to work a full day today at work so only got 2 hours to work on the car today.
    one thing to note, you NEED to break down your used front axles, keep the inner Cone for the Rear, bolt the OUTER cone into the Knuckle/bearing. this cone holds the bearing halves together and the bearing in the knuckle. If you don't have it, your first drive will end VERY badly.
  2. #122
    Huntsville, Al
    it's only just sitting there...if you look close the bolts are still rusty and not torque striped.....I still have to finish the install...I just needed a side done so my brother has something to look at as an example.
  3. #123
    Aug 2011
    Logan, UT
    good, just making sure that's clear. I would cry if i saw that it happened the first drive, especially if I didn't mention it.
  4. #124
    Denver, CO
    This is exciting! Now I need to get instant updates all day during work.
  5. #125
    Erik, did you just spray paint the bulkhead aluminum?
    Are those red? rivets provided?
  6. #126
    Huntsville, Al
    I epoxy coated the aluminum.
    the rivets are powdercoated red...rivets are provide but they are plain aluminum colored...so they are still in the bag.
  7. #127
    Tulsa, OK
    Erik, I am really enjoying this thread. Thank you for posting.
    2011 Nissan LEAF
    2007 Dodge RAM 3500
    2006 Subaru WRX STi
    1996 Chevy Tahoe
    1968 Camaro Convertible
    1959 Chevy Apache Fleetside
  8. #128
    Beverly Hills, FL
    After building my Cobra with plain aluminum panels, I plan on painting them when I build my 818s (probably a year before I can order it).
    FFR4958. IRS, 408W, Loud and fast!
  9. #129
    Mechie3's Avatar
    Quote Originally Posted by blueoval_bowtie_guy View Post
    Any specific reason?
    Hide dirt?
    Looks?
    Heat?
  10. #130
    Beverly Hills, FL
    Hide dirt?
    Looks?
    Heat?
    Looks and to make it easier to clean.
    I used Fatmat insulation under the carpet, so I do have a little isolation from the heat. Even with powered footbox vents, my Cobra interior gets miserable hot.
  11. #131
    Edmonton, Alberta
    I was considering spraying the inside and outside of the cockpit with lizard-skin, for heat and sound deadining. Definitely want to paint it at least though. Nothing worse than dirty pitted aluminum.
  12. #132
    krylon spray epoxy or something else?
  13. #133
    Senior Member cmcintyre's Avatar
    Danbury, CT
    This was used by the publisher of Kit Car Magazine when he did his Roadster and wrote a book on the build.
    http://www.eastwood.com/sharkhide-al...FUGk4AodvkcAWQ
    Anybody else have experience with it?
    " That which is rightly done, however humble, is noble." Sir Henry Royce
    SN 46 In the building 10/4/13.
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
  14. #134
    Senior Member AZPete's Avatar
    I used Sharkhide on the aluminum panels, and other metals parts, on my roadster. When I sold it after 2 years the panels looked new and it was easy to clean but realize that I live in the Arizona desert with lots of heat and dust but no salty roads. I'm now coating 818 parts in Sharkhide and I'll use it on the panels when I get my kit in August.
    Regarding insulation, look at EZCool. It's a foil backed foam that is used in NASCAR and it's very effective for heat and noise, plus it's MUCH lighter than other stuff.
    http://www.lobucrod.com/
    Pete
  15. #135
    Mechie3's Avatar
    Erik hasn't posted yet. Since yesterday morning. Either he's busy working, or someone else found him and took his kit.
  16. #136
    Senior Member Xusia's Avatar
    Eugene, OR, USA
    Wasn't Wayne on his way there, last we heard from him?? Hmm...
  17. #137
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    I was there last night, he's working hard on it. Sent me a pic an hour ago and the front suspension and brakes are on.
  18. #138
    Huntsville, Al
    ok guys...sorry....long day at work yesterday and had to pick up my brother at the airport... Wayne and I worked on few things, but mostly walked around the car and talked about the path ahead..also helped him load up...
    today...lot's of progress...a good 5 hours...
    just playing
  19. #139
    Nepa
    Very nice. Looks like lots of progress in only 5 hours.
  20. #140
    Mechie3's Avatar
    Nice. What size and offset is that front wheel?
  21. #141
    Huntsville, Al
    18 x 8.5 +45 offset
  22. #142
    Portland, OR
    I love those wheels. Thank you for taking the time to post pictures and discuss your build. I'm sure there a ton of lurkers on this forum like myself that check this site multiple times a day hoping you have an update.
  23. #143
    Owensboro, KY
    You can not believe how slow these 9 days are going to go by me gazing at this build thread!
    FFR '33 #325 built with hazelwwp & FFR 818-S #11 Delivered on July 21, 2013
    Facebook 818-S/R Build Page: https://www.facebook.com/pages/Facto...78385198877613
    Forum 818-S/R Build Thread: http://thefactoryfiveforum.com/showt...-Build-Thread!
    FFR Project 818 Owner's Registry on Google Map
  24. #144
    I was going to use a stock rad for the weight, but these aluminum ones look so much more substantial. Why the tilt though?
    Also click the pics, quite a bit more on his photobucket.
  25. #145
    Senior Member JAubin's Avatar
    Goffstown, NH
    Awesome photos, some really nice prep work and detail in your build already! I wonder how distorted everyone's view that is new to building a kit car (myself included) is getting in seeing how fast you're putting yours together.
  26. #146
    Beverly Hills, FL
    Quote Originally Posted by thestigwins View Post
    I too think there are a lot of lurkers (myself included!).
    I can't wait to see the finished result and hear what Erik has to say about the finished product.
  27. #147
    Beverly Hills, FL
    The tilt is to get the radiator to fit under the hood.
    Thanks for telling us about photobucket!
  28. #148
    Mechie3's Avatar
    Do we need to reuse the stock hardlines for the brakes or fuel? I've been storing these since last year and they don't store neatly. It'd be nice to finally fold them up into the scrap bucket.
  29. #149
    Mechie, I know the rest of the kits from FFR com with new hardlines, but I defer to Erik for the definitive answer.
    BTW I hope no one gets the idea that their kit will go together as fast a Erik's or Wayne's. Both of these guys are notorious for their fast building skills! They are perfect guys to be doing the first builds, because if there are any issues with the kit, they will find them fast! We really couldn't have a better set of guys doing the first builds.
    PS I do have one request for you Erik. Can you post pics to an album here?
  30. #150
    Huntsville, Al
    Dave , sure. no problem at all.. I was just thinking about that. I will start with today's updates after we setup to get the car on the ground with the engine in it
    stay tuned...
  31. #151
    Beverly Hills, FL
    stay tuned...
    What a tease! Damn, I do have to get some work done sometime today. I can't just keep hitting refresh!
  32. #152
    Senior Member gwader's Avatar
    Torrance
    Finally more pics! Your making some great progress.
  33. #153
    Exeter R.I
    I can not wait to build mine soon
  34. #154
    Brisbane, Australia
    Erik, I see from the photos you are building on car stands. I'll have to have a trolley/dolly because I'm short on build space nad will need to move it against a wall when I'm not working on it.
    Can you please post the measurements front/back and side/side (and possibly a couple of photos) so I can get the trolly/dolly started?
  35. #155
    Those wheels are nice. I would like to see how deep the concave face would be on the rear ones.
    But hey Erik, something flammable right underneath the car? I hope you don't smoke!
  36. #156
    Tulsa, OK
    What kind of radiator is that?
    2011 Nissan LEAF
    2007 Dodge RAM 3500
    2006 Subaru WRX STi
    1996 Chevy Tahoe
  37. #157
    Huntsville, Al
    Well.... another 4 hours or so on the Flash today... I think...well....it looks ..... OK.... maybe I will go ahead and finish it..... ARE YOU KIDDING ME>>>>> this thing looks hot!!! I was going to paint it right away....but man-o-man I am digging the wheels with the white....
    My Brother enjoying the day!!! Good job Blake thanks for the HELP!!!!!
    ok.. now we need a motor!
    All turned around and ready for install of the motor in the morning....
  38. #158
    Jun 2012
    Wow, go on vacation and leave the internet behind for a few days and look what happens. Keep up the good work!
  39. #159
    Aliso Viejo, CA
    where'd you get the seats? How do they fit?
  40. #160
    Huntsville, Al
    I got them on ebay...$298- free ship (2 days) with seat adjusters... fit right in the hole..seem ok...we totally just threw them in the hole for the pic.,,they feel super comfortable for the 3 mins I sat in them... I really need to make sure they really do fit, but I think they look pretty good regardless.
