Results 1 to 3 of 3
Thread: RLTCS for '33 Hot-Rod
    Owensboro, KY
    Look here for more info. Most people decide to put a 8 cyl engine in their, roadster, coupe, GTM, or '33 and RaceLogic Traction-Control Systems makes TC systems specifically for 8 cyl engines. The systems range from $1,100 to $1,300:
    - RLTC8ALD (ATC 8 C+LC+DL)
    - RLTC8ALDW (ATC 8 Cyl+LC+DL (TCWSSSET required))
    - RLTC8DIA (ATC 8 Cyl+LC+DL+DA)
    - RLTC8DIAW (ATC 8 Cyl+LC+DL+DA (TCWSSSET required))
    The TCWSSSET are a set of 4 wheel speed senors if your donor didn't have any abs senors or you chose not to include them on your build. There is currently a group-buy going on (see above link) in the 818 sub-forum for a RLTC system. If you think you need to have ordered an 818 to get on of their systems/add-on(s) then you're wrong. It's open to all builders. The above prices are without the discount applied, once applied, it bumps the $1,100 price down to $750 (around due to the always changing exchange rate between pounds and dollars) and the $1,300 price down to $880. If you check on the original thread there's more info (link above). Hope to see more people join!
    FFR '33 #325 built with hazelwwp & FFR 818-S #11 Delivered on July 21, 2013
    Facebook 818-S/R Build Page: https://www.facebook.com/pages/Facto...78385198877613
    Forum 818-S/R Build Thread: http://thefactoryfiveforum.com/showt...-Build-Thread!
    FFR Project 818 Owner's Registry on Google Map
    Owensboro, KY
    Bump
    Owensboro, KY
    Last bump
