Page 5 of 6 FirstFirst ... 3456 LastLast
Results 161 to 200 of 226
Thread: Bob and Mike's 818Se Build Thread
  1. #161
    Senior Member Oppenheimer's Avatar
    Milford, CT
    I may have to use the ICE to tow the EV to the track.
    This may sound silly to some. I'm thinking of mounting a hitch ball up-sided-down in the transmission mounting plate. Then turn the coupler over on my race tire trailer.
    818 towing an 818, that will be a sight! A lot of people will be confused seeing that...
  2. #162
    Mar 2013
    My Powder coater just sent me some of the pictures. I'll publish more details later.
    Attachment 23514Attachment 23515Attachment 23516Attachment 23517Attachment 23518
    Did you have to get the frame sandblasted first? I've got my frame at the powder coater's place and he's saying the slag from laser cutting isn't ideal for powder coating. I'd like to think he knows what he's talking about but if no one else bothers blasting theirs then I won't either.
  3. #163
    Freeport, ME
    Blast it! the coating will stick much better.
  4. #164
    Quote Originally Posted by theburner9 View Post
    He sand blasted first, then washed, then phosphate etched, then powder chrome, then powder translucent blue.
    He has been powder coating for my business since 1997. But 98% of his powder coating is industrial machines and parts.
  5. #165
    Has anyone thought about putting radiator on the back wall of the car above the transmission instead of in the front.
    What would be the advantages/disadvantages?
  6. #166
    Usually that's not a very efficient spot, aerodynamics wise.
    If they are in the back or 3/4 rear area, they normally are in a place where there's lots of air flow.
    I did check about that and what I understood is if the car isn't designed to have them in the rear it may well not work in an efficient manner. I couldn't find many cars with rads in the back. It seems the Aventador has it int eh 3/4: http://www.carbodydesign.com/2011/05...or-the-design/
  7. #167
    Status of Bob and Mike 818SE electric Vehicle
    Back on thanksgiving Michael and I made the decision to build our second 818 chassis a gas engine.
    We are trying to have it ready for the coming Autocross season. So all our focus has been on the second 818.
    Here are some pictures of the Electric version as it sits waiting for it's turn.
    Encinitas, CA
    poor neglected step-child!
  9. #169
    Aliso Viejo, CA
    Nice 888's. Best looking tire out there.
  10. #170
    with an additional transaxle like that one, how hard would it be to make this AWD?
    would the cost be significant?
  11. #171
    I can push the motor intermittently with my controller to 250 HP.
    The gearbox is 98% eff so 245 WHP.
    My battery peak output is 300 HP. So no need on this car for another motor.
    The original plan for the second car was 4 100Hp motors on each wheel. I have the motors and batteries. A custom gearbox would have to be designed. Something like the picture.
    That plan is on hold for now.
  12. #172
    Ontario, Canada
    Hey Bob.
    That motor/egear drive looks good. What do you know about the acceptable angles the egear is ok with regarding mounting? I read somewhere that is could be set at different angles. . . but I can't seem to find where I read that.
    So, you must know Jeff Major huh??
  13. #173
    Ontario, Canada
    It's probably less of an issue with the electric drive vs an ice application. The heat dissipation for an ice is huge in comparison. If you have thermostatic controlled electric fans on the rad for your application, I think you could mount it almost anywhere. . . assuming it had free flow space around it and wasn't getting opposite air pressure from fwd motion of course. It would depend on size of rad, flow rate, temp delta required etc....to be specific.
  14. #174
    Ontario, Canada
    Are you able to get the drive mounted so you have equal length half shafts?
  15. #175
    Quote Originally Posted by Gary Livingston View Post
    Hey Bob.
    Hey Gary,
    acceptable angles are 10 deg to 90 deg.
    I got my start in EV's in 1994 working with Jeff on Formula Lightning.
    And many other projects over the last 20 years.
    That car is in a museum now. I must be getting old.
    I can get equal length half shafts if I mount the motor behind the axle.
    I think I have about 50 half shafts for that transmission with ford outers.
    Ontario, Canada
    Hey Gary,
    Thanks very much, that's exactly what I was looking for.
    LOL, ya, I hear ya. . .just don't slow down. I've not been in the game that long, but must admit I'm pretty hooked.
    Jeff is a plethora of information. I learned a lot from him. He helped me (theoretically, I did all the work lol) make one 13" series motor out of a couple compound wound motors. He knows more about electric motors than anyone else I know. . . . and continues to help a lot of people on the DIY forum.
  18. #178
    Edmonton, Alberta
    Think you could fit it in the front? Not sure how simple it would be to move the coilovers. I'm dreaming of F1 style(batteries) KERS with Porsche GT3 Hybrid (flywheel, designed for F1) delivery. (ie. rwd going into the corner, awd coming out) Is this plausible, or a pipe dream? I guess anything is possible, and its being done in different forms with HUGE budgets, but how plausible on a DIY scale?
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
  19. #179
    Things are tight in the front. Coil overs, frame, and steering column are all in the way.
    I would start from scratch on firewall forward to put 2 motors in there.
    It is all plausible on a DIY scale because all the building block are out there.
    Finding the time while have a job is the hard part.
    Edmonton, Alberta
    I got time, but not a clue. I get confused reading Erik's thread every time. Can you suggest a book or resource to learn the basics of building a EV? I've tried some forums, but it's all over my head.
    818 SRX - #91
    Arrived 01/02/2014
  21. #181
    All electric vehicle have 4 main components.
    Charger, battery, motor controller, motor.
    Then there 3 or 4 technologies for each of these.
    Let me know what part you need help with an I will try and explain.
    this was my first book 20 years ago.
    http://www.amazon.com/Build-Your-Own.../dp/B0015DRPHC
    I have that book
    You need to get your electric 818 going so you can get into EVCCON for free with it: http://evtv.me/evccon/
  23. #183
    Quote Originally Posted by rtz View Post
    I have that book
    I might be there.
  24. #184
    Ontario, Canada
    Stay tuned. . . it's coming. My build will be AWD (818SeX4).
  25. #185
    AWD? I was waiting for one to be made before I decided on my engine setup. Too bad I already jumped.
    Make it great, we want to see that AWD! This will launch like hell!!
  26. #186
    Encinitas, CA
    That will be fun to watch. When I explain the concept of 818 to people I always have to re-iterate, no it's not AWD, even though it's a Subie drivetrain...
    OK, now whose going to be the first to try to build a hybrid? (EJ in back/electric in front)?
  27. #187
    Edmonton, Alberta
    Such a tease!
    818 SRX - #91
    Arrived 01/02/2014
  28. #188
    Ontario, Canada
    Such a tease!
    I don't want to hi-jack this fine thread. . . and it's a bit early to start gabbing about it. Getting it worked out in my little brain right now.
  29. #189
    Do you think they will let me compete in Formula E with my 818Se?
    https://www.youtube.com/watch?v=IptB...e=youtube_gdat
  30. #190
    Bob,
    Do you have any plans to sell off some half shafts?
    Cheers
  31. #191
    Quote Originally Posted by Jodie View Post
    Bob,
    Cheers
    Yes I will sell most. Bob
  32. #192
    I haven't had much time lately to work on my electric 818.
    But it looks like I made it into a movie for about 1 second.
    http://www.traileraddict.com/on-any-...hapter/trailer
    I was congratulating Carlin Dunne after our Pike Peak Victory last summer. (fastest motorcycle up the mountain)
    Looks like a good movie to me.
    Off Topic Motorcycle
    I'm Hijacking my own thread.
    My 818 progress has been slow because of other projects.
    This weekend we introduced our new electric superbike at the Quail Motorcycle Gathering.
    Called the LS-218 (after the speed we achieved at Bonneville) This is very similar to the bike that won with at Pikes Peak last summer.
    He is my an article about it.
    http://www.asphaltandrubber.com/bike...c-superbike-2/
  34. #194
    218mph????
  35. #195
    218mph????
    yes, the 2 way average was 215.960MPH
    http://green.autoblog.com/2011/08/24...rd-to-215-960/
    More info if you interested
    http://lightningmotorcycle.com/news/
  36. #196
    Jesus, that is quick! That is freaking quick on a bike!
    Is that bike streetable and for sale? I mean the blue one, not the black one on your green.autoblog link.
    Actually, the blue one went up to 218 as well?
  37. #197
    Yes and Yes, 38k for the worlds fastest production Motorcycle.
    http://lightningmotorcycle.com/reserve-now/
    Blue one is latest greatest. The land speed bike was an earlier prototype. I think the land speed bike is the one in my profile.
    On of my favorite pictures after winning the 2010 TTXGP national championship at VIR.
    Richard Hatfield (lightning CEO) Jeff Major (EV Guru) Stephanie (Daughter) Michael (Son) and Myself.
    Not Pictured is our rider Michael Barnes (Barney)
  38. #198
    Exeter R.I
    Wow
  39. #199
    The sound of future racing.
    Here is a clip from this years IOM race.
    First 2 bike are electric and the 3rd on is gas.
    I will have 818 of both types.
  40. #200
    Not trying to downplay 218, because it's really fast. But, to put it in perspective, my fifteen year old Hayabusa could do 196 straight out of the showroom. A $3500 turbo kit later and you have 220.
    In the early 2000's when I used to be into this stuff, Lee Shierts did 250 at Maxton, which is only a mile long with limited shutdown room. A streetable bike did 272 last year. The crazy part about Maxton is that your top speed isn't limited by power, but by brakes and craziness. You can only go so fast because the shutdown area has a turn a half mile into it.
