Results 1 to 40 of 445
Thread: JeromeS13's 818S
Threaded View
    Suisun City, CA
    JeromeS13's 818S
    Well, I guess it's time to start a build thread...
    I've been in the Subaru family since 2009. I previously had a 2008 Subaru Impreza STi that I purchased nearly stock (had a Cobb Accessport). After getting pretty heavy into HPDE with NASA AZ, the car was eventually turned into a completely gutted Time Attack car.
    Well, the car was making almost 500 AWHP and apparently I have bad luck with motors... After breaking a few, I decided that I wanted to change to a lighter platform, which would require less power/stress to go fast. That's when I stumbled across the Factory Five Racing Project 818.
    I placed my pre-order for my 818S on 7 December 2012. Initially, I had a build date of 14 February 2014. After Factory Five established a "Hot List" for people who wanted to get theirs quicker (due to other people cancelling or pushing their production dates back), I ended up with a final production date of 9 November 2013!!!
    I purchased my donor (2006 WRX with 123k miles) in May 2013 from Copart for $4,800 (includes shipping). The car had a fair amount of front end damage, which didn't really concern me because I have planned on upgrading the shortblock and heads from the beginning.
    So far, I've sold $3,150 worth of parts from the donor. So, I'm only into my donor for $1,650. Off to a good start.
    818 Parts List
    Engine
    LIC Motorsports B1 Short Block (2.5L)
    B25 Heads (’06 WRX)
    Supertech Valves / Springs / Titanium Retainers
    LIC Motorsports Timing Belt Idlers
    LIC Motorsports Air Pump Delete Kit
    ARP Head Studs
    Gates Timing Belt Kit
    Grimmspeed Crank Pulley
    Cosworth TGV Deletes
    Moroso Oil Pickup
    OEM ’06 WRX Oil Pump
    Tomei Turbo Inlet
    Custom Extended Intake / Intercooler Piping / Exhaust (Fathead Fabrication)
    JDM VF37 Twin Scroll Turbo / Header / Uppipe
    Boyd Welding Aluminum Fuel Tank
    Cusco Engine Mounts
    FrozenBoost Type 3 Air-to-Water Intercooler
    FrozenBoost Type 118 Heat Exchanger
    FrozenBoost Reservoir
    Suspension
    VeryCoolParts Trailing Arms
    Whiteline Rear Lateral Links
    ARP Wheel Studs
    Perrin Fuel Rail Kit
    TurboSmart FPR-1200 Fuel Pressure Regulator
    Injector Dynamics 1000cc Injectors
    TurboSmart Race Port Blowoff Valve
    Cobb Accessport w/ Snail Performance Pro Tune
    NGK LFR7AIX Spark Plugs
    ReplicaParts.com Alternator Mount Kit
    ReplicaParts.com Brake/Clutch Master Cylinder Remove Reservoir Kit
    Zero Decibel Motorsports Upper Coolant Reservoir Relocation Kit
    Zero Decibel Motorsports Upper Radiator Brackets
    Deka ETX14 Battery (11 lbs)
    Drivetrain
    VeryCoolParts K-Tuned Shifter
    Cusco Transmission Mount
    Rori’s Shifter Rod Arm
    Rori’s Push/Pull Bracket
    2012 WRX Transmission
    Brakes
    OEM 4/2 Pot Brakes (’06 WRX)
    Centric Premium Rotors
    Centric PosiQuiet Pads (Street)
    Hawk Blue Pads (Track)
    Stainless Braided Lines
    ATE Type 200 Brake Fluid
    Exterior
    Enkei Kojin 17x8 +45 (10mm spacers) Front
    Enkei Kojin 18x9.5 +45 (13mm spacers) Rear
    Federal 595 RS-R 235/40/17 Front
    Federal 595 RS-R 265/35/18 Rear
    Interior
    AiM Sport MXL Pista Digital Dash
    Sparco 353 Steering Wheel
    Sparco Steering Wheel Hub
    Sparco Ergo M Driver Seat
    Sparco Evo II Passenger Seat
    Rori’s Steering Column Spacer
    Sparco 6 Point Harnesses (Driver is HANS version)
