Remounting the hard line bracket on the front side of the tube. That's where I fitted mine after test fitting with my custom length braided lines.
818S Chassis #288 2.5L 323hp
joshuajach.com
I ended up using a pickle fork and getting it off pretty easily. They're awesome tools.
Weight distribution! I figure it helps offset the fact that I'm on the driver side. I figure besides me, there is steering and fuel filler neck, probably nearly offset by the extra exhaust stuff on the right. I bet left to right, with coolant run on the pass. side it's pretty close to even.
