Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 203
Thread: Chedda's 818S build thread
  1. #121
    Quote Originally Posted by chedda View Post
    yes, I had put the heads on but they were put on at OEM torque specs. All went well going in until I moved the car. The bolts snapped. Good thing they snapped now and not while running the motor.
    ARP studs have a specific torque value and method, which is unique from the OEM spec.
    When you mention the "cam cover" you mean the valve covers, right? Those go on with barely any torque, just till they start to snug up, and don't forget the RTV at the cam cap corners.
    The actual cam caps (the bolt-on bearing part) has an incorrect torque spec in the 02 FSM for the smaller two bolts per cam (front pair)
    Also, if you lap the sealing surfaces of the valves, you should re-check valve lash, it's likely tight now.
    -Andrew
  2. #122
    Oct 2014
    Denver, CO
    Yeah I put the head studs in at the proper torque but they somehow got stripped. I am thinking it was from the socket when I was taking them off.
    As for the cam covers, these are the few that got stripped.
    The valves are being lashed and new seals are being installed. We completed one head last night and it was looking pretty good. Things were lining up very nicely. I will have pics of the heads tonight.
  3. #123
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    The FSM calls for 14.7 on those and it is wrong. There is a revised manual that calls for 7 on the end caps, 14.7 on the others. If you did 14.7 on the end caps (circled in your picture), you'll break them every time (we did too).
    Tamra
    First autocross 3/29/15
  4. #124
    Oct 2014
    Denver, CO
    Mine held until the car started moving. They snapped right off once the motor was building pressure. Thankfully there was very little scoring on the heads and were able to be machined out. I'll take some pictures of them when I go back to the shop today.
  5. #125
    Oct 2014
    Denver, CO
    One head almost done.
  6. #126
    Leesburg, VA
    In the photo, the right cylinder chamber looks like there might be two small cracks between the valve and spark plug threads. It could be an optical illusion but you may want to double check, it's a common problem on the 2.0 heads.
  7. #127
    Oct 2014
    Denver, CO
    It is a very good optical illusion just a random marking.
  8. #128
    Oct 2014
    Denver, CO
    Well, last night was kind of productive...
    Windscreen holder is on!
    Left Heads
    We had a dead soldier when polishing. It got launched across the room and hit 2 walls. Pretty impressive. Luckily we had some on standby. It has a very slight bend and it didn't make me happy with the sliding motion.
    My buddy is putting the left head back on as we speak! Squeee! TGV Delete is happening also today so there might be a chance that the motor will go back in today, if not tomorrow.
  9. #129
    Oct 2014
    Denver, CO
    Great job on the build. I love the wheels. I know the rears are 17x9 +45, mind sharing what the fronts are?
    The fronts are also the same. I wanted the extra grip in the front as well since it will be taking high speed turns. I have 5mm spacers in the front and it almost clears front wall. I am going to try 10mm and 15mm spacers to see what clears properly.
  10. #130
    Senior Member R.Spec's Avatar
    Portland, Oregon
    You have no idea how much I am also struggling with those damn coolant hoses onto the corrugated crap. I wanted to punch a hole in my face. GRRRRRR Idk what to do. I am using subaru hoses. Maybe I will buy some gates from oreilly and see if they are a touch larger.
  11. #131
    Puyallup, WA
    Quote Originally Posted by R.Spec View Post
    I would go with larger hoses. I had two connections blow out during the dyno tuning. Worth the $15 now to not be stranded on the side of the road.
  12. #132
    Portland, Oregon
    Yeah I read that in your post a couple pages back. Which hoses did you end up going with? Should I just go down to oreillys and try stuff out?
  13. #133
    Puyallup, WA
    Exactly. Mine ended up being the outer diameter of the OEM hose to be the new inner diameter of the NAPA replacements. Bends to match what you need. You can usually find one hose to have multiple bends that you need in one.
  14. #134
    Oct 2014
    Denver, CO
    I was never really a fan of the bending hoses. They can hold air in between ripples and may cause flow issues. The tubes from ReplicaParts.com are pretty awesome and they are bent perfectly.
    I had some fun last night. I got the other head on and did the timing belt.
    AAAAAAAND.... It's in again
    I didn't take anymore pictures since I was cleaning up the shop and putting the cherry picker back in its closet space. Hopefully the TGV's are going to be deleted and polished today. I am going to take a break today since I have been at the shop from after work to about midnight to 1AM. Getting up at 5AM and doing it all over again is killing me slowly and I miss the GF.
    Before I put the headers back on, I am going to be head wrapping them. I didn't like how close they ran to the oil pan. I thought about ceramic coating but the cheaper option would be the heat wrap. Plus it is lighter doing that too. I want to start this damn thing next week.
  15. #135
    Progress is looking good and are getting closet. You mentioned you were getting an iWire harness, what are you using to start it next weekend? Keep up the good work and keep us posted. Looks like based on the build threads we may still be able to have a 818 meet in Colorado late summer.
  16. #136
    Oct 2014
    Denver, CO
    Yep, Brian at iwire is doing my harness. I have yet to send it to him since he is so far out. I am just going to set all the cabling out and plug in all the stuff needed to run.
  17. #137
    Best of luck. It's a big step and very rewarding when you get to go rip around the neighborhood. Keep us posted
  18. #138
    Oct 2014
    Denver, CO
    Things have been pretty slow. My buddy and I are meticulous on deleting the TGV's perfectly. Unfortunately I don't have any before and after pics, just in the middle of welding the holes shut. I know, bad Mikey....
    But while we were doing all of that, I decided to clean the transmission since everything else was all sorts of shiny.
    Before:
    After:
    And then the TGV's were done and also cleaned the intake manifold along with everything else on it. Here it is almost all the way put back together.
    I will be heading to the shop tonight. Last night I had no progress since I got screening tickets to the Avengers (which was awesome btw). The exhaust heat wrap came in so now I can wrap up the headers. I want to wire up the fuel connectors just to start it. I can't find any documentation as to what connector goes to what on the donor fuel tank. My harness is an '04. I can't wait for Brian at iWire to say, hey! yours harness is coming up soon. Send in your stuff dude haha.
  19. #139
    Oct 2014
    Denver, CO
    Well, she is back together. I didn't take pics since my buddy was being silly and fell off the roof. he is ok but just really sore. I will post pics when I go back over there today hopefully. (Yes he is dumb when he drinks vodka haha)
  20. #140
    Senior Member Quiny's Avatar
    Massachusetts
    I noticed the clutch fork return spring, was that stock? There wasn't one on mine but there is a spot for it. I wondering if I should use it. I have go-karted about 10 miles without one and it seems to be ok. I also don't recall seeing anyone else with one. It actually looks like a clutch assist spring like its trying to apply the clutch.
  21. #141
    Over long periods with the clutch not depressed, the arm is allowed to vibrate against the clutch cylinder, which could pack the actuator arm in. Then, when it comes time to use the clutch, it may take a few pumps to get it firm again. Not that I've ever seen it happen, but that's my understanding of why its there.
  22. #142
    Oct 2014
    Denver, CO
    You are correct Jaime. Since the car will be in storage in the winter time, I don't want the clutch fork pushing so much on the actuator and being a PITA.
    I'm getting super excited to start it this week. yay! I will record the event when it happens.
  23. #143
    Oct 2014
    Denver, CO
    Well, I didn't get a chance to start it yet. My buddy that is making me brake and clutch lines called up and said bring the car over. I did manage to take new pics before we moved it for you guys.
    Here it is put back together and cleaned
    Shenanigans
    I put the front seats back in and installed the brackets. I got 1 left backet and 3 right brackets for the seats. I had to chop up one of them to make it work but I eventually got it after a few hours of cutting and "custom" fitting haha.
    Fixed up the lock issue of rubbing. Good thing I have grooves in the tires in just the right spot. Super lucky haha
  24. #144
    Oct 2014
    Denver, CO
    Some bit of news as of late. I have the steel braided lines in and flushed. I just need to secure them and I can finally check that off my list. I have sent my wire harness to Brian at iWire. Hopefully he gets to it soon. I am eager to get it started
    I am going to start mocking up my exhaust and had a really neat idea. Could anyone take a picture for me with their body panels on in this direction?
  25. #145
    Feb 2014
    Ramona, CA
    not my car...
  26. #146
    Oct 2014
    Denver, CO
    Thanks! that is the exact angle but the only problem is that it is black. I can't really mock up the exhaust and carbon fiber cover properly.
  27. #147
    How about this picture
  28. #148
    Oct 2014
    Denver, CO
    That is perfect! Thank you so much!
  29. #149
    Oct 2014
    Denver, CO
    Well, There has been many updates since my last posting. I have had quite a few setbacks and then got sick for 3 weeks in the middle of all of it. I have mounted quite a bit since. I put in the shifter, e-brake, oh yeah! The wire-harness from iwire! Brian does a top notch job!
    I know it doesn't sound too happy. It is running very very lean for the amount of mods and airflow. It is using the stock tune just for the first start.
  30. #150
    Congrats on the start!!
    Dumb question, are you sure every cylinder was firing? Sounded a bit odd at first.
  31. #151
    Oct 2014
    Denver, CO
    Once the motor gets to about 2500-3k the motor flattens out and is happy. Idle is very rough since there is not enough gas going in. It has new coil packs and sparks.
  32. #152
    Oct 2014
    Denver, CO
    Has anyone gotten burnt out on this project? I'm tired of things going wrong all the time and frustrations galore.
  33. #153
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    A number of times. A few people on the forum gave me some good advice last time it happened to me: Create lists on paper. Refer to them while you are bored at work or whatever. Shuffle stuff around on the to-do list so it's in the perfect order. Make sub-tasks etc. Then when you feel like working on the car, you can cross items off your list as you do them and it helps you see the forward progress. May not work for everyone but has definitely helped me.
    All that said, your build has progressed very quickly so that could explain the burnout. Maybe pace yourself a bit more?
  34. #154
    Oct 2014
    Denver, CO
    I wouldn't say it is the build progress in the speed. At this point, I just want the motor to run so I can move on. I have been stuck at this point for a very very long time. Upgrade here, modify this, machine that. The damn thing runs like ****. I have taken the motor apart 4 times now and every time it is something new. The motor is a complete rebuild and new parts. I dunno....
  35. #155
    Apr 2014
    Shelton, CT
    Is it a problem with the motor or does it just need a tune? If you are running the stock tune it probably won't run well. Between the TGV deletes, the lack of exhaust back pressure, and any other changes you made in the build, I would imagine it would run terribly on the stock tune.
    Tamra
  36. #156
    Oct 2014
    Denver, CO
    I have low pressure on the passenger side. pressure goes to each cylinder cycle. 140,120,150,120. I have not done a leak down test but once I get that, what else is next?
    As far as the tune, I have used the accessport to use a OTS map from cobb to support the mods except the TGV delete.
  37. #157
    Leesburg, VA
    Have you data logged or monitored your AFR? Just keep trouble shooting different systems and you'll figure it out. Sometimes its a bad sensor, or a bend before the MAF, or bad ground on one of the coil packs or something like that. I've gotten frustrated many times but I refuse to give up. You've made quick progress, just take a step back and regroup. The more you tell us, the more we can help. Why did you take the motor apart so many times? Find any signs of damage? Is there an air leak? Does it rev ok?
  38. #158
    Oct 2014
    Denver, CO
    I haven't logged any data as of yet.
    First time I took it apart was because the heads were bad. I put the new heads on. The head bolts snapped in the block. Got a new block and ARP head studs. Put it all together and it looked all fine and dandy. I put the timing belt on and then the cams weren't lining up right. Took it apart and lined everything up. Everything went well and looked correct. Filled it with oil to check for leaks. Primed the motor and one of the heads started to leak. Took the heads off again, machined it all, took the time to polish the valves. Put the heads back on and primed the motor again. No leaks yay! Hooked everything up and started the motor. Things don't sound right, shut it off and retune for what it needs. Troubleshot the motor and since it has a vf39 maybe it was looking for more fuel. Put in WRX dark blue 560cc injectors. Tuned it once again and still runs the same. The only thing we can come up with was that there was not enough pressure somewhere. Did a pressure test and found not enough on the passenger side. The driver side has one that has too much. good thing? lol So now here I sit, having to take the motor out again... and see what is going on. Possible that the lashing on the valves not correct, bad heads, shims are not right, new motor borked somehow? I've been having motor issues since December.
    One of the heads sounds not happy like it is slapping. No air leak. When it warms up, it sounds the same. When revv'd to 3k it sounds almost normal but not.
  39. #159
    Apr 2014
    Shelton, CT
    I would think that an off the shelf tune is probably not sufficient for your mods list. I would see about bringing the car to a tuner to see if they can assist. They can also help diagnose if the issue is with the tune or the engine itself.
    Assuming the problem is the engine and not the tune, have you considered simplifying things for yourself and either sending the motor out to a professional or just picking up a stock longblock and using it?
    Tamra
  40. #160
    Member 508wrx's Avatar
    Nov 2012
    Taunton, Ma
    That sounds exactly like my car did on first start. Try to get a new cam position sensor (its on the driver side near the oil filler neck) or make sure it is plugged in. Mine ran like that when it had no cam sensor.
    Also, Are you running open turbo in that video? I can't see a downpipe... maybe its just the angle of the video.
    "aerodynamics is for people who can't build engines" - some old dude
    "Shut up! I know what I'm doing" - some angry finn
