Trans arrived from The Race Line. (Actually it came close to a month ago but its been a busy summer). I have a team of 3 friends heading to my house on Sept 12th to get this sucker installed.
Came in this heavy plastic box.
The Flywheel and adapter plates that came with the kit
Shipping can be hard on something this heavy. Would have been better if a piece of plywood or a 2x4 was under the trans, it bashed right through the bottom.
This is what came in the first shipment.
And of course the trans.
And again.
This is the shifter and cables that came with the kit.
Another shipment came a little later (Month after) that included the clutch, axle pieces, bearings, etc.
I now have everything i need, I am just having a little trouble figuring out which hardware to use as I am heading into uncharted territory.
Details
G96.01 New factory reman unit, inverted with cooler in and out ports installed.
New Adapter kit to LS with flywheel
Stage II clutch kit complete
New Cable shift assy
Starter
Slave cylinder
clutch release components
inner cv joint assy complete
bolt kit
LSD
