Likes Likes:  3
Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 161 to 200 of 477
Thread: JJ's 818s Build
  1. #161
    Sep 2014
    Dallas, TX
    New injectors are on hold. Once I put them in I cant drive it anymore until it gets tuned again. My plan is to register first then upgrade injectors, turbo and boost controller. I installed a Walbro fuel pump already.
    818S Chassis #288 2.5L 323hp
    joshuajach.com
  2. #162
    nkw8181's Avatar
    Dallas, TX
    Alright alright you can beat me to making it street legal. Then I'll just do what you do
    Nolan
  3. #163
    Sep 2014
    Dallas, TX
    Got all the side panels installed and aligned. Waiting on Craig's hood hinges before installing hood latches.
    This picture makes me happy
    joshuajach.com
  4. #164
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    Looks good. Nice job!
    Larry
  5. #165
    Aotearoa (New Zealand)
    Quote Originally Posted by TouchStone View Post
    looks amazing! love the red
    __________________________________________________ _____________
    That man is no fool, who gives what he cannot keep to gain what he cannot lose
  6. #166
    Yeah the red and black together look really great, nice cut of colors.
  7. #167
    Sep 2014
    Dallas, TX
    Its out of the garage!
    joshuajach.com
  8. #168
    Frankfort, IL
    Looking good. Congrats on the milestone. Are you able to go ahead with registration now that the body "shell" is fully in place?
  9. #169
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    I don't see any hood pins yet so I imagine he still has a bit to go. Considering that though, your body fits really well just laid in place! Our rear deck lid wants to pop up in the corners way more.
    Tamra
    First autocross 3/29/15
  10. #170
    Freeport, ME
    Quote Originally Posted by Tamra View Post
    The sun and gravity are your friends... I used gallon containers to add to the gravity piece
  11. #171
    Red is great!
  12. #172
    Senior Member metros's Avatar
    NoVA
    The red looks really good. I had ruled painting red out because my last 2 fun cars were red. But this has me re-thinking that.
    Your body lines look great. I'll be very happy if I can get mine to line up as nice as yours does.
  13. #173
    If those are the blue wrx injectors, you can grind off the restrictor plates on the end and get ~800cc. I did that and had them cleaned/flow tested. All were within 5cc at 824cc. My tuner didn't like them at first but I got a buttery smooth 318awhp 328awtq. (vf39, walboro 255lph,BC280 cams). I can get a lot more power but I had him limit the tune for the sake of the glass box. So far I have ~5k miles with no issues.
  14. #174
    Sep 2014
    Dallas, TX
    Quote Originally Posted by billjr212 View Post
    The top panels are just laid in place, waiting for Craig's hood hinges. Once the panel are all secured I'll try to get it registered.
    I've trimmed my deck lid a bit to help with the corners popping up, they still pop up if you bump the car at all.
    That is just the red gel-coat. It looks great in pictures and from a distance.
    joshuajach.com
  15. #175
    Sep 2014
    Dallas, TX
    Got a couple nice features working this weekend. The Sparco steering wheel hub does not come with a workable solution for the horn. It does however have a contact ring, so I rigged up a custom solution using a Dorman pin http://www.amazon.com and a mechanical pencil. I'll find out how long this will last eventually.
    The red piece is the shell of a mechanical pencil cut to size.
    I glued these parts together so that the red part acts as support for the spring and wire.
    Found a good location on the column and epoxied it in place.
    With the Sparco Hub in place the the spring is slightly compressed, maintaining a connection during rotation.
    joshuajach.com
  16. #176
    Sep 2014
    Dallas, TX
    Also fixed the turn signal so that it will auto turn off when exiting a turn. I used a small exhaust pipe I found at O'Reilly's and duplicated the OEM function. I was planning to weld the pipe to the sparco hub but I turns out the hub was non-magnetic, so I guess its cast aluminum. I got frustrated and impatient so I ended up with a bit of a hack.
    The angle brackets aren't bolted to the hub, instead they are acting as a clamp.
    joshuajach.com
  17. #177
    nkw8181's Avatar
    Dallas, TX
    Looking good!
    Nolan
  18. #178
    Sep 2014
    Dallas, TX
    Hazard Light switch installed. I've wired it to blink along with the turn signal lights.
    joshuajach.com
  19. #179
    Sep 2014
    Dallas, TX
    I haven't seen many 818s with outside door handles. So I went out on a limb and installed these handles I got off ebay. Very easy installation.
    joshuajach.com
  20. #180
    Jan 2012
    Nice looking handles. What are they off of? Do you have a link to the auction you got them from. I was personally looking at maybe doing GTR handles, I like the way that they pop out when in use plus it would be rice so it would instantly add like 15hp
  21. #181
    Sep 2014
    Dallas, TX
    Quote Originally Posted by 07FIREBLADE View Post
    Thats 15hp per handle!
    Left and Right were sold separately:
    http://www.ebay.com/itm/371064017334...%3AMEBIDX%3AIT
    http://www.ebay.com/itm/271493405643...%3AMEBIDX%3AIT
    joshuajach.com
  22. #182
    USA
    I need to modify my momo hub to flip the blinkers off after a turn. I think I'm following what you did, but any additional detail would be appreciated.
  23. #183
    Frankfort, IL
    Anything special about that hazard light switch? I was thinking about ditching the oem Subaru one and putting in something like that.
  24. #184
    Sep 2014
    Dallas, TX
    You'll want a latching DPDT or DPST. If you want the switch led to blink with the turn signals you'll need an additional diode.
    http://www.aliexpress.com/item/19mm-...909881091.html
    I wired mine like this:
    joshuajach.com
  25. #185
    Hazard switch, really nice looking (handles too!), by blinking with the flashers, you mean every time you toggle a flasher it will blink the switch's light?
  26. #186
    Sep 2014
    Dallas, TX
    What you want to happen is this: When using the turn signal (left or right) the hazard button indicator light does not turn on. Only when the hazard button is pressed does the hazard light blink.
    If you don't use the extra diode then the hazard button light will turn on when using the left turn signal.
    joshuajach.com
  27. #187
    How interesting!
  28. #188
    Senior Member Quiny's Avatar
    Massachusetts
    I did something similar since I didn't like the OEM switch. I had to use a 3pdt relay (non-latching) and an after market hazard button. I did not wire the LED in the switch to blink I tied it with the dash lights so I can see it at night.
  29. #189
    Sep 2014
    Dallas, TX
    Quote Originally Posted by Quiny View Post
    Not a bad idea, now I may add a resistor so that the LED is at half brightness at night.
    joshuajach.com
  30. #190
    Sep 2014
    Dallas, TX
    Texas is great, I got a 30 day permit for my car for $25. Will let me drive my car around enough to get it inspected and fully registered.
    joshuajach.com
  31. #191
    Mechie3's Avatar
    Texas is great, but Indiana doesn't inspect. lol.
    I shipped your hood hinges out today at lunch. I'll send you tracking info.
  32. #192
    Sep 2014
    Dallas, TX
    First Autocross
    I participated in my first ever autocross event last Sunday. It was a lot fun and very exciting. Was a bit nervous to race for the first time especially in a car like this. Spun out in 3 of my 5 runs .
    Certainly got alot of attention.
    joshuajach.com
  33. #193
    Way to go Josh.
  34. #194
    Mechie3's Avatar
    Spinning is good. If you never spin you're never trying to find the limit.
  35. #195
    Michael and I must be really good. We've lost count of the spins. Probably 30-40.
  36. #196
    Sep 2014
    Dallas, TX
    Installed Craig's hood hinges. It looks great unpainted and works great, anything to cut back on the hood pins.
    Its an easy install, would have been easier if the front bumper wasn't in the way. I also think it needs a spacer between the bracket and the hood to prevent the hood from warping when bolted together. For now a bunch of washers will do.
    Bondo is still drying.
    joshuajach.com
  37. #197
    Apr 2014
    Shelton, CT
    Nice!
    Tamra
  38. #198
    Mechie3's Avatar
    That was quick. Lol.
  39. #199
    Sep 2014
    Dallas, TX
    Installed 550# springs on the rear. I'm wondering if the larger outer diameter is going to be a problem? The inner diameter is correct.
    Also found my noise problem when going over moderately sized bumps. The flange that attaches the fender of the front bumper clips the wheels. I had trimmed this earlier, apparently wasn't enough.
    joshuajach.com
  40. #200
    Sep 2014
    Dallas, TX
    My donor turbo is looking pretty slick. New chra, ported, clocked and ceramic coated.
    joshuajach.com
