Likes Likes:  3
Page 1 of 5 123 ... LastLast
Results 1 to 40 of 161
Thread: bbjones121 - Denver build
Hybrid View
    Denver, CO
    My descriptions will be pretty short, I am going to try keeping it mostly to pictures if i can.
    My donor is a 2006 WRX sedan bought on salvage auction, shipped from Seattle. It was hit in front and timing had skipped a couple teeth on the belt, so I tore down the engine to look for any damage. Thankfully there was none.
    So after lots of thinking, I decided to keep my chassis bare until i completely build the car. There are some things i will most likely be welding along the way. I want it all powdercoated, including all my rivnuts.
    I plan to start stock WRX 180ish whp for my vin registration and inspection. When i take it all apart for powdercoating, I have parts to build my motor up and run e85 close to 380whp.
    Enough typing, here we go...
    Oh yeah, the most important thing to say and I almost forgot. I want to thank everyone who has gone before me and documented your work, it has been extremely valuable. I can't truly express my full appreciation and gratitude for everyone's time and energy.
    Denver, CO
    Denver, CO
    Garage Remodel
    Garage remodel. Took way to long, but a 240v electric heater will warm the garage from freezing to comfortable in about 20mins now.
    Before.
    During.
    Finishing.
    Cleanup.
    Denver, CO
    Denver, CO
    Steering Rack
    Steering rack depowering.
    All ports cut off and welded. Pinion welded. Steel and aluminum polished and clear coated.
    Kirkland, WA
    Build is looking real nice, I like what you have done with rear firewall, I don't like rivets/rivnuts either. Whast kind of welder do you have for the aluminum ?
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Denver, CO
    Thanks.
    It is an Everlast 200dv. If you talk to them, they can work with you on price. I think for about 1400 I got the dual voltage model, upgraded pedal, upgraded gas regulator, upgraded tig torch, plus the another tig torch with the thumb current adjuster,I love it. Used an old Lincoln a bit back in the day and i wouldn't give this Everlast up. The functionality is insane. It has great warranty, pretty nice Siemens IGBTs I think.
    For aluminum you can adjust everything and you can use a sharp point on your electrode. You can weld the bottoms of pop cans difficultly. The next model up can do it easily.
    Does it sounds like I researched a bit?
    Denver, CO
    Mechie3's Avatar
    Indianapolis
    Looking good. Car and garage. What heater are you using?
    Zero Decibel Motorsports
    Check out my new website!
    Denver, CO
    Thanks. It is the Dr Heater 988. Little red box.
    NY
    Awesome, looking good!
    Senior Member AZPete's Avatar
    You do nice work. Keep the photos coming please.
    QC, Canada
    Really good to see your build thread for progress and follow-ups!
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Denver, CO
    Brake caliper powdercoating.
    I knew those huge seat boxes would come in handy.
    Two coat chrome and candy orange.
    Denver, CO
    I dont know if this pops as much as i would like. What do you all think?
    Mechie3's Avatar
    Indianapolis
    Looks copperish in the photo. Not sure if it's the lighting or the actual part. I like the FFR logo though. It feels more OEM than "818" on the calipers.
    Frankfort, IL
    nice progress and I like the calipers and logos. Agree that they look copper.
    Curious, where are you hosting your photos? Most (including my own) don't show up for me at work since I'm behind a firewall (imgur and photobucket are blocked).
    Keep the pictures coming!
    San Diego Ca 92106
    Anything is better than "Bronco" orange. lol
    Seriously though, that color gives it a sophisticated look, I like it.
    Denver, CO
    Yeah, the lighting is bad in the photo. They are lighter. I will try to get some better photos with them on the car this weekend.
    I am using google+ for photo location. If you right click a photo, you can copy the url. I just past that url in here.
    Denver, CO
    Brake Caliper Color
    Final brake color:
    Illusion orange plus clear vision topcoat from prismaticpowders
    Denver, CO
    Steering and pedals.
    Denver, CO
    Final Steering rack.
    Polished and ports ground off and welded shut
    Looking good. Moving along nicely.
    Denver, CO
    Pedals
    Final pedal location.
    Welded and supported the gas pedal mount.
    The bracket flexes a lot and the manual calls for rivnut mounting to the chassis, even worse. The whole gas pedal assembly flexes over an inch when you push it down. I bet you would bend the bracket if you were racing.
    I flattened the upper section which sit perfectly on the back side of the clutch shaft tube in the donor pedal box. I cut the top and welded it to the tube. There was still flex, so I used the top piece and made a support.
    Senior Member TouchStone's Avatar
    Sep 2014
    Dallas, TX
    Does your clutch pedal still work after the welding?
    818S Chassis #288 2.5L 323hp
    Ordered: 9/19/14 Received Kit: 11/2/14 First Start: 5/31/15 First Drive: 6/7/15 Registered: 3/10/2016 Completed: 2/10/2017
    Status: Complete Build Thread Sold 9/22/2017
    joshuajach.com
    QC, Canada
    Quote Originally Posted by TouchStone View Post
    Yeah I second that, the tube its welded on turns when you press on the clutch.
    Denver, CO
    Haha. Yeah it does. Come on...give me a little credit that i wouldn't do that . I tried to keep my weld from bonding to the inner tube. As far as i can tell there is no added friction.
    Trust me though...i have done plenty of stupid things. Especially with the rear bearings, abs ring, seals when i powdercoated the rear uprights.
    I think it would be easy for FFR to add an extra tab that you could rivet to the pedal box where i welded the back brace (not the tube part).
    Denver, CO
    Wheels and Tires
    Factory five gunmetal wheels with Federal 595rsr 255/35-18 in rear and 210/40-17 in front.
    Denver, CO
    Finally mounting the seats. Sparco sliders angled up to allow seats to go up over the angled square tube a bit.
    Oct 2014
    Denver, CO
    Fantastic progress! I can't wait to see the final product.
    Denver, CO
    Thanks chedda. How is yours coming along?
    Oct 2014
    Denver, CO
    5 steps forward, 3 steps back but this time for the better. My build is sitting at ZFABmotorsports for the exhaust mockup and build but then the motor started leaking...
    Denver, CO
    Quote Originally Posted by chedda View Post
    Bummer, sorry to hear, hopefully it is an easy fix.
    Oct 2014
    Denver, CO
    The heads went to the machine shop. My thread shows all the pictures and what not. It happens when building motors right? lol
    Denver, CO
    I just saw the pics. Yeah, I will be crossing my fingers when I start mine up. Good luck.
    Oct 2014
    Denver, CO
    If you ever want to come by and check it out, you are welcome to do so
    Denver, CO
    Would like to. Are you around this weekend?
    Denver, CO
    Radiator mounted and complete. Mechies brackets work and look great! I welded my own supports to the chassis so they can be powder coated later.
    Denver, CO
    Seats mounted and done. Making the sliding rails work is a pain!
    Puyallup, WA
    Quality work. Keep on with the progress. One milestone at a time.
