Page 3 of 3 FirstFirst 123
Results 81 to 86 of 86
Thread: Jason's 33 "Scootin' Thunder"
    I love the personal touches you put on the 33, well done.
    I was drawn to the Hotrod because so many of them are unique and not just another clone.
    Dale
    Jun 2012
    CrossRoads, Pa.
    Did you use the original trunk hinges or make new ones to do the reverse trunk opening? A terrific job by the way.
    thanks,
    Nevin
    Nevin, AKA H. R. Lucky
    Member 3dGuy's Avatar
    San Jose
    Yes is was the same hinges. Using them saved some fab work. I like how it all turned out. The only down side came from the placement needing to be in the middle in order to clear the back of the body. with the two hinges close together there is a lot more freeplay and wobble back and forth. thankfully it isn't to much of a problem with the two gas lift springs helping to support/limit it.
    My build site : www.ScootinThunder33.com
    What kind of wheels are you using. They fit the theme well.
    Great fab work, by the way.
    San Jose
    They are Rhino armory wheels, normally meant for a wrangler. A bit heavy but looks great. 17" 255 front 285 rear
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    Awesome!! Very nice design...
    Took some time!!
    Robert
