29
38
This thread is so helpful. Thanks.
I threaded in the 6 drive shaft adapter bolts with the lock tight. Then I threaded in the 4 drive shaft connecting bolts temporarily. I slipped a breaker bar in between 2 opposing drive shaft bolt heads and used that as resistance while I torqued the 6 adapter bolts. It was easier than applying the resistance at the spindle.
