Thanks Thanks:  3
Likes Likes:  3
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 41 to 80 of 249
Thread: Wyoming 818R Build Thread
    Mar 2015
    I'm about to do the coolant mod. Is this the proper place?
    Thanks in Advance
    Mechie3's Avatar
    Thats it.
    Feb 2014
    Asheville, NC
    Awesome build thread. You take some great pictures and do some great work. Keep it up, man!
    Leesburg, VA
    Quote Originally Posted by shoeish View Post
    So I mounted up my Air/Water Seperator. Hopefully this image helps somebody. I *think* its correct. I also bypassed the heater, so somebody let me know if I'm correct or not on that too.
    1. 1/2" hose To the driver side head, T with #2
    2. 1/2" hose To the passenger side head, T with #1
    3. 1/2" hose From T of #1 and #2 to Top side mount on AWS
    4. 3/4" hose on crawford to hose resizer down to 1/2, to...
    5. 1/2" hose inlet on intake
    6. 5/8" hose to Y that goes to crankcase goes to...
    7. Right under #3 on AWS
    8. 1/2" hose from side of Y to...
    9. Very bottom of AWS
    10. 3/4" hose from bottom of Y to crankcase
    11. 1/2" hose from the curved and notched tube on the side of the AWS to...
    12. Degas tank.
    13. 1/2" hose to Turbo coolant to
    14. Straight and notched tube on side of AWS
    15. 5/8 hose from coolant manifold directly on top of block to...
    16. Coolant return? This bypasses the HEATER. (Note on a wrx: You don't have to do this, you'll want your heater)
    Your water routing to the degas tank and placement of the degas tank looks ok but I didn't see a return line from the bottom of the tank back to the water pump. Make sure you have plenty of flex in the water lines from the degas tank to the engine as you've rigidly mounted the tank on the frame (it's normally mounted to the engine and moves with the engine).
    Did you delete your PCV? Either 6 or 8 normally runs to the PCV (located on intake manifold right below throttle body). If you deleted it, remember to plug the hole in the IM.
    BTW, beautiful build and attention to detail.
    Mar 2015
    The degas Tank is still on the engine, I built a little angle bracket to move the cap from under the cross-brace. My drawing might have been a little deceiving.
    The bottom hose of the degas tank goes to the factory location.
    The PCV valve location is removed and capped.
    Thanks everybody.
    Shoeish,
    It's all looking great.
    My degas tank is right where you drawing is. I raised it to get better degassing and easier bleeding.
    I heard the FFR is coming out with a bleeding procedure video. You may want to hold off on your drilling.
    Mar 2015
    I drilled it and tapped it anyway. VERY easy. Make sure to use 3/8" NPT threaded tap for the 1/8" nipple NAPA has. Go NICE and easy. In a little, out a little, in more, out more, repeat. Practice on a chunk of scrap aluminum if you are worried. It was easy to get to with the help of a ratchet strap holding the intake tube out of the way.
    This is what my degas tank relocation bracket looks like. (Edit: If you look closely you will see my single vacuum leak I had before tuning)
    Intercooler installed along with Crawford Air/Oil seperator. I'll add another piece of heat tube when it comes in. My bracket solution was once again taking a length of iron and hammering it around my $
    Mar 2015
    Underneath, just because.
    Feb 2014
    Asheville, NC
    Does the AOS work if the bottom of it is lower than the port on top of the engine?
    Mar 2015
    I sure hope it does. I should have room to move it up if needed.
    Sep 2014
    Dallas, TX
    12. Degas tank.
    I think Wayne's coolant mod is great, but wouldn't it be easier to T a degas line to hose 16? No drilling required and it sticks up higher than the coolant manifold.
    818S Chassis #288 2.5L 323hp
    joshuajach.com
    Yes that looks right but that AOS isn't going to work that low. The bottom line from the AOS needs to have a downward angle all the way to fitting on the engine block. If it doesn't, the oil won't drain from it. It will collect in the AOS and/or the lines. The line slope doesn't have to be much at all... the important thing is that it's always going down or horizontal, it can never go up at any point.
    I have the same AOS. I mounted it to the top of the frame near the coolant degas tank (had to create some brackets to do that). See my build thread for pics. However, this places the AOS higher than the degas and the degas should be the highest point in the system. The Crawford guys told me it wouldn't be an issue because the system is under pressure but I still don't like it. I also don't like the under-sized de-gas tank, and the fact that it isn't see through so you can't check your coolant level by just looking at it. So my next step is to fab up a new degas tank that's a little larger and then I will mount it to the top of the frame in the same place as the AOS. It all fits under the hump of the engine cover. If you want to stick with the OE degas tank, I'm sure it probably would be fine....I'm just overly particular about things like that.
    Here is a link to the post that shows my AOS setup: http://thefactoryfiveforum.com/showt...l=1#post206505
    Mar 2015
    Thanks for the information. Does your hood clear that thing? What is the clearance I have to work with?
    Yeah look at the pic on the top... the engine cover is on and it's hard to see from that angle but it clears it by 1/2" or so. It can be tight, because it's mounted to the frame not the engine so it isn't going to be moving around. Note in the pic, that the bottom of the AOS is roughly even with the bottom of the frame tube. That should give you a rough idea on mocking it up on your own car, if you choose to go this route. Of course, always put the engine cover on to test before drilling, cutting, or welding.
    Mar 2015
    Ah, got ya. Time to redo it, again!
    What is the product you used for your rear firewall?
    DEI Floor & Tunnel Shield II
    https://www.designengineering.com//c...-sound-insulat
    Has some fiberglass on the back and then an adhesive on the back of that. I taped the edges with aluminum duct tape and bolted it to the frame with self-drilling sheet metal screws.
    Mar 2015
    Alright... the last week I made some more progress. But first, I had to undo everything I was proud of because I learned the AWS has to be above things. If the coolant being that high is an issue I'll bypass the AWS and just run it, I'm sick of moving the thing.
    UNDO ALL THE THINGS
    REDO ALL THE THINGS
    Huge Milestone: Set battery in, plugged it in, and was able to flash the Cobb programming onto the ECU in preparation for the base map.
    Mar 2015
    Building a dash:
    The iWire/Longacre racing panel is SUPERCOOL.....
    but it interferred with my ability to copy Andrew & Tamra's awesome dash/gauge design. So I took a picture of the back, removed each thing...
    and copied hole sizes on to my dash.
    Remember how I mentioned how much of a ricer the kid I bought my donor car was? Look closely and you'll see some of it leaking into my build.
    Mar 2015
    For gauges, I got my gauges from https://www.maxtow.com/black-maxtow-...-gauge-series/
    Save 10%: Save10now
    They are really, really neat. So I can watch my motor blow up in Digital AND analog.
    For them to mount behind the dash you'll need to remove 5/16th of an inch from the U brackets.
    Apr 2015
    Colorado
    Great job, Looks great, Where are you in Wyo? I am in Ft Collins C.O. I would love to come up and see your build sometime. Plan to have my MK4 done this spring/summer. Would be a great drive.
    Mar 2015
    I'm up in Gillette, WY. I will have my car at SCR Performance eventually to get it double checked, aligned, and dyno-tuned. I believe that I will get it started this weekend if my fuel pressure gauge comes in. Cheers!
    Mechie3's Avatar
    I've done the undo all the things redo all the things too many times to count.
    Mar 2015
    I've made a ton of progress and believe I am ready to start it tonight, once my accessport gets back with the tune loaded on. WOOT! This thread will have lots of out of order pictures.
    So I had the gauges mounted in the dash then realized a fuel pressure regulator, nor the damper, was on my fuel rails. This is the mess I soldered up to hook my five gauges up.
    1. Boost
    2. Oil Pressure
    3. Oil Temp
    4. Fuel Pressure
    5. Dual Air Intake Temperature Gauge.
    4 and 5 will be mounted in the console.
    Make sure to mark each wire as you run it forward so you know which gauge to plug it in to.
    I ran all the wires to the engine and got them loomed up pretty.
    The wire from iWire to power the AWIC pump just didn't seem beefy enough, so I bought a relay, fired off of the ignition on circuit from iwire, and wired it right to the battery with a 15a fuse.
    Mar 2015
    I bought exhaust from AJW Performance. It's way sweet.
    Random picture of my seats:
    READY FOR OIL:
    Mar 2015
    Random shots that others will either use as a resource or tell me where I've screwed up.
    Mar 2015
    More random pictures.
    Mar 2015
    Smoke Check of the gauges.
    Mar 2015
    Smoke check the starter and build oil pressure:
    With sound:
    https://www.youtube.com/watch?v=fs6T...ature=youtu.be
    Tonight I shall add fuel, set my Fuel Pressure Regulator to 44psi, upload my 1000cc injector base tune, and fire it up! I'll get my Gopro with good audio rigged up so we can all hear the AJW exhaust.
    Mechie3's Avatar
    The Bosch pump is only suppose to draw about 3amps max during operation.
    Mar 2015
    Well... I got my tune, and...
    https://youtu.be/p56-6DfX1vI
    YES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    That is all.
    Senior Member AZPete's Avatar
    YES!!!!!!!!
    sounds great, but what's all that white stuff on your lawn?
    Feb 2014
    Asheville, NC
    Yeah! Congrats! A wildly exciting moment.
    Mar 2015
    I was able to work on my center console a bit. I have the upgraded shifter, but I wanted that more for function than appearence. I researched forming carbon fiber and then bought a roll of carbon fiber looking adhesive.
    I used this for a removable wheel hub:
    NRG Innovations SRK-100H Short Steering Wheel Hubs
    https://www.amazon.com/gp/product/B002EWR3WK/
    NRG Steering Wheel Quick Release Kit - Black Gen 3 - Part # SRK-650BK
    https://www.amazon.com/gp/product/B005GMA6VA/
    And this steering wheel, which has a horn I have yet to figure out how to wire:
    OMP Racing OMP-OD/1990/NN SUPERQUADRO: Flat 320mm steering wheel | Black/yellow suede
    http://www.amazon.com/gp/product/B003V5188O
    Mar 2015
    Also installed is this very nice USB kit:
    http://www.amazon.com/gp/product/B00XJDP12W
    and
    https://www.amazon.com/gp/product/B00XDSA82Q
    If anybody cares, this is what I'm using for carbon fiber vinyl.
    https://www.amazon.com/gp/product/B00CPN0BB8
    It's pretty thick and nice stuff.
    Senior Member Mulry's Avatar
    Dallas
    Horn wire should work like this. Run hot power from your fuse box to the signal side of the horn relay. Run the ground for relay signal to the post on your horn switch. When you press the horn button you complete the signal circuit in the relay and then the power side sends power to the horns (which you ground to frame). We used those same Hella horns on our MR2 Lemons car because we found that people wandering the paddock often couldn't hear our mid-engined engine, but they could always hear those horns!
    Build's looking great BTW. I like the kph speedo
    Feb 2014
    Asheville, NC
    Just some food for thought-
    on their race car, FFR ran both coolant lines on the passenger side. So did I, as you can see here. Just for better weight distribution, but it's a lot easy to undo and redo (sigh, yet again, right??) now than it will be once you have the body on.
    Mar 2015
    I bought the pre-bent coolant tubes from Breeze Automotive for a fairly significant dollar amount so I don't have plans to redo it.
    Stunning build!
    One question/issue that I can see though: your air filter/intake & MAF placement may have issues. Several builds have been finding temperature issues in the engine compartment. I don't know how aggressive you are planning to vent yours; but with the air filter & MAF tucked in & so close to the turbo, it might become a problem -especially since the EJ doesn't like high intake temperatures.
    Any plans to address this by intake vents/heat shields or isolating the intake track?
    Mar 2015
    Quote Originally Posted by mikeb75 View Post
    Stunning build!
    Hi Mike. Thanks! As for AIT, I'm really hoping that my really big (frozenboost says "600hp") air to water intercooler will be most of the solution. I don't plan to run super high boost and I have a really efficient turbo for the boost I'll be running so I'm thinking no matter whatever hot air comes out of the turbo I'll have enough cooling to bring the intake temps close to ambient, or closer to what the EJ likes.
    Mar 2015
    I made some center console progress. I plan to run the Accessport mounted somewhere but I hate how the OBD cable is always in the driver's way, so I decided to mount it on the passenger side. Also, to eliminate the business of crawling around in cramped quarters and misplacing the blue plug, I am putting switches in.
    The plugs I speak of:
    The switches:
    Three holes:
    Antirattle solution:
    Where it ended up:
    I'll get things powder coated then install everything more permanently.
