It has been a while since I have updated the thread. I am now registered and have put about 100 miles on it. Removed the body yesterday to finish up a couple of loose ends and begin to check all the nuts and bolts to insure nothing is backing off. Not sure how most do it but even though I am registered, all my sheet metal is still cleco'd and the wiring wasn't complete. So the body is off so I can begin to complete it before off to paint.
So, the control pack. Two things to update.
1. The clutch bottom switch (CBT) page 4 of the control pack install guide.
https://performanceparts.ford.com/do...-6017-504V.pdf I didn't final install this but to enable getting this switch to work for me to start the engine, I ended up taking the upper portion (the portion where the plug inserts into the switch) and just installing it 180 deg or clocked in an 180 deg in relation to its original orientation. That worked to date but did notice while sitting at a stop light, if you counted to about 7, the engine RPM would raise about 100 rpm and stay that way until you took off. I believe this makes sense, the PCM is seeing the CBT or clutch depressed all the time while the CTT (clutch top switch) stays open, signaling that the clutch is never depressed. Imagine this is confusing the PCM. So while the body is off I am converting to a signal switch and using another brake light switch configured to provide the open/closed signal to the PCM. Will report out if that fixes the high idle after sitting phenomenon. Since I am converting two switches to one, thus raising the resistance would drop the current so relatively confident I will not damage anything in the PCM. Fingers crossed!!
2. The second issue I ran across. My tach hasn't worked since day one. I used edwardB's recommendation to connect to the #7 cylinder. To enable my Ultra-Lite tach to work, I had to purchase the autometer tach adapter.
http://www.autometer.com/tach-adapter.html Once I purchased this and hooked up to the #7 cylinder, it did not read while hooked to the yellow COP wire. I actually had to hook it up to the purple wire going to #7. Still want to do some more troubleshooting as the tach needle bounces more than I would like to see.
Hope this helps those installing the new control pack.
