Page 2 of 2 FirstFirst 12
Results 41 to 64 of 64
Thread: MK4 Coyote with a modern twist
    That is one sensational build! Well done!
    Member Paquette173's Avatar
    Thank you guys
    Very happy that i went 4mm more agressif to get that 3" rear lip for the wheels. The wiring is started and i must say Edward is a huge help !!
    The suspension will need some ajustements. The body is on since i left for vacation and my guys can ajust the side pipe, windshield and alot more
    Senior Member D2W's Avatar
    Spokane, WA
    Do you have a build thread for the mini? I've been looking at doing a BEC myself and would love to see your buildup.
    I can do anything with enough time and money.
    Quote Originally Posted by D2W View Post
    I do but but its in french and most of the pictures are gone. check you'r PM
    So finaly got the top after 6 months, wasn't expecting having it this ruff. There's going to be alot of work needed, manly Trimming it to lower it and have it fit perfectly. The top is from Bruce i payed 500$ for the hardware, didn't get the rear window and i was surprised to only get a few metal brackets for my 500$.
    Once its done and lowered it should look something like this.
    Very busy at work, the cobra is sitting at the body shop. They trimmed and installed the side pipes, only missing to install the windshield and trim the hardtop. I might be changing the leather of the dash for all alcantara, a bit like a superleggera. What you guys think ?
    started to work on the windshield. Does the angle look right ?
    Also what did you guys do for the gaps ?
    Boy, he sure left you a lot of work to do on that top! Based on the rest of your build, I know you will get it right.
    I enjoy your updates, and your car looks great!
    I look forward to seeing the rest of your build.
    Member BobCarter's Avatar
    Springfield, MO
    Paquette-
    What is your source for the thermal insulation in the foot boxes?
    Beautiful job! A "10"
    "The top is from Bruce i payed 500$ for the hardware, didn't get the rear window and i was surprised to only get a few metal brackets for my 500$. "
    No comment
    hell yeah its crazy !! my body guys are telling me, more hours on the top then the mk4 itself ! I'm finaly back at it
    Quote Originally Posted by BobCarter View Post
    Paquette-
    I got it from a local shop witch is specialized for body shops. I can try to find out whats the name of it.
    Quote Originally Posted by 2FAST4U View Post
    Thank you, slowing getting there.
    Last day at the body shop.
    First day home, had to slam it
    Installed a front and rear sway bar
    Worked on the Oil filtrer relocator and oil cooler
    Also did the mod for the rear quick jacks, took 3/4'' off to get them tighter on the body
    Fuel lines, prestone reservoir and the powersteering is hooked up and ready to go.
    Looking nice. You are doing very nice work!
    Thanks for posting the update and the great pictures.
    Bought a new house that needed some renovation to put it at my taste. Also built a nice seperated garage for the Toys. Since thats done, i can finaly get back on the cobra.
    Still working on that top !
    Had to add 1/2" to match the door lines.
    The top is nice and solid molded to the body, very easy to pop off.
    Molded the bracket for the rear hatch
    They also worked on the windshield ton make it perfect
    Can't wait to bring it home, get it striper down and start it
    Member rx7922's Avatar
    Gilroy, Ca
    oh man this is exciting! cant wait to see if done!
    Gilroy, Ca
    Dreaming of the MK4
    Purchasing the kit within the next 3 years.
    It’s Been awhile since I havn’t updated my build.
    The top is done ! The car is painted, A/c system is bleeded and should be working, windows are done, carpet is done, dash is almost done. We might have a finished car within a few months.
    Chino Valley, Arizona
    Quote Originally Posted by Paquette173 View Post
    The wheels are in, Pretty nice !!
    Ripped the intake so i can work on the AC systeme.
    All the big aluminum panels are in place *tu* man it takes long to install that
    The headers are so close to the foot boxes, this isolation is realy needed.
    Absolutely love that steering wheel and I’m assuming your working on a “murdered out” (learned that from my adult kids) - look. Very nice craftsmanship and your ripping along...
    The silver-gray is stunning in contrast to your carbon black wheels. Really look forward to seeing this finished.
  18. Likes Geoff H liked this post
  19. #58
    Nice work. I love the top.
    -Steve.
  20. #59
    Senior Member Geoff H's Avatar
    Edmonton, Alberta
    Great work! Can you tell me more about how you mounted the steering wheel? Did you redrill the FFR boss?
    Geoff
    Edit: I found the information earlier on in your build. Thanks.
  21. #60
    Quote Originally Posted by Geoff H View Post
    Geoff
    Thanks guys, yes the car will be murdered out !
    For the steering wheel, i got a quick release and custom fab a spacer to make it fit.
  22. #61
    May 2019
    Any pics of the AC system installed? Looking at that myself but can't find many builds doing Coyote and A/C, much less any pics or information on what was required.
  23. #62
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Looks sharp! Can’t wait to see a finished pic.
    Kyle
  24. #63
    The car is pretty much 98% done. I must say a BIG thank you to EdwardB, you were great help and a real inspiration to finish the car !
    Here's a few pictures at a local race track, that is unfortunately closing at the end of the summer.
  25. #64
    Thanks for the shout-out. You're certainly welcome for whatever help I provided. You did all the heaving lifting! Your car looks great. Lots of interesting touches there. Congratulations.
