Thanks Thanks:  7
Likes Likes:  3
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 134
Thread: Post Your Weights
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    So my car weighs abt the same as Bob's, but I have no dry sump or add on bumpers. Starting to wonder if the scales I was weighed on were wrong lol. I don't get why my car is so pudgy!
    Hindsight's Avatar
    Atlanta
    AAIC** Oops! So, I don't have a splitter or wing yet ($), I don't have front fender liners, and in this measurement I didn't have my windshield wiper. Did that help in the difference?
    I don't think any of that really weighs much. I have none of that installed on mine yet either.
    Sgt.Gator's Avatar
    Bend, Oregon
    Bump. We must have some more 818s +r ready for spring track time!
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Sep 2014
    No completed "C"s yet ? guessing 2200 based in completed "S" models shown.
    Kirkland, WA
    I check the mail each day for my prize but still nothing has shown up
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Sgt.Gator's Avatar
    Bend, Oregon
    Have you weighed since you added 50lbs of wrap? You may not have the prize anymore!
    818R ICSCC SPM
  7. #87
    Kirkland, WA
    Yes, I was at 1851, with dry sump, wrap, dash, etc. so not sure if I am still in the lead or if I have fallen off
    Tony Nadalin
  8. #88
    Kirkland, WA
    So I was working on my challenge car over the weekend, making sure it is ready for the season and was doing the alignment and cross balance and looks like the challenge car is about 500 lbs more than the 818R, so I'm about 100lb over the minimum of 2400 for the challenge car
    Tony Nadalin
  9. #89
    Banned
    I'm now at 1,796 after a winter diet (Flywheel, fans, winder-shield washer, different wheels+tires, misc trans and engine brackets.) Probably still a few pounds left in replacing the seats and battery.
  10. #90
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    FFR's 818R with oils, fluids and no gas 1956 lbs, exactly 60/40 weight R/R distribution. R/L distribution is 50.2/49.8 with me in it.
  11. #91
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by phil1734 View Post
    We have a new winner!
    And an S too!
    I'll edit your listing, post up your new corner weights if you get a chance too.
    If you have a standard battery you can lose 20lbs with a LI-Ion battery. I've learned a great deal about them the last few months.... if you decide to go that route be very careful. I'm a dealer for EarthX batteries now. They are primarily in the aircraft market but are making a push for the automotive racing market.
    818R ICSCC SPM
  12. #92
    Banned
    Didn't realize the batteries had gotten that light. I'll definitely have to give it more consideration now seeing as my donor battery is at least ten years old anyway. Do you still need a special trickle charger for the li-ion?
    Seats should be in within a few weeks so I'll do a full update then.
  13. #93
    Administrator
    Enterprise Alabama
    , yes lithium batteries do require a special charger
  14. #94
    Sgt.Gator's Avatar
    Bend, Oregon
    In danger of threadjacking my own thread, but:
    It depends!
    From EarthX on their batteries:
    In the event you have to charge the battery, use a Lithium (LiFePO4) battery charger or a lead-acid battery charger that does not charge above 14.6V, will automatically turns off when the battery is fully charged (based on volts) and does not have a de-sulfate mode. Do not use any charger with voltage that pulses above 15V! This will damage the battery. If in doubt, consult the manual that comes with your charger.
    For chargers with a maintenance mode, the maintenance mode voltage should be 13.3V – 13.9V. For example, the Battery Tender JR has a maintenance mode voltage of 13.3V which is compatible, whereas the original Battery Tender or Battery Tender Plus has a maintenance mode voltage of 13.2V which is too low for a lithium battery. Please read the manual that comes with your charger.
    There's more at this link including a list of chargers that will , and those that will not, work:
    http://earthxbatteries.com/our-batte...ttery-charging
    The Tenergy LiFePO4 Battery Pack Charger is on the list and is also recommended by InduraPower who I met at the PRI show.
    818R ICSCC SPM
  15. #95
    Banned
    Alright - full report from the summer tweaks.
    [tr]
    [td]Phil1734[/td]
    [td]818S[/td]
    [td] (lbs)[/td]
    [td]1793 (lbs)[/td]
    [td]372[/td]
    [td]395[/td]
    [td]526[/td]
    [td]500[/td]
    [td]2.5NA, Gen2 nose, Post #95 for full specs[/td]
    [/tr]
    Full specs: 2003 TS Wagon donor. 13lb flywheel. Everything from kit installed except carpet and parking brake boot. Mostly vinyl wrapped interior. Wiper kit. iWire harness. Rocker extensions and big fiberglass hooptie wing/third brake light mount. FFR wheels. Kirkey intermediate road race seats. Momo Quark steering wheel. Not a single fan on it, including the radiator. Just some crafty ducting. Still have a lead-acid boat anchor up front to start the thing. No radio or anything that could be accidentally construed as a "luxury."
    Because of the variations in full tanks that are used, I topped off and subtracted 78lbs (12 gallons) worth of fuel according to my weight distribution. Not an industry standard, but it allows better comparison to other builds and everybody is reporting with a random fuel load anyway. So technically curb weight is 1,871, but that doesn't sound as nice.
    P.S. Anyone over 2400lbs (coupes) on a stock WRX engine have a worse hp/lb ratio than my car.
  16. #96
    Sgt.Gator's Avatar
    Bend, Oregon
    Thanks Phil. I edited the table with your new info. Great to see an NA Build coming in nice and light!
    Although Tony is still the leader because his weight includes 7 gals of fuel.
    818R ICSCC SPM
  17. #97
    Banned
    For sure.
    I might get him if I switch to Li-ion and finish trimming the body. I swear FFR mixes depleted uranium dust into their fiberglass resin.
  18. #98
    Sgt.Gator's Avatar
    Bend, Oregon
    For sure.
    If you go Li-ion: I'm a EarthX dealer and can get you one at a good price. PM me. They have features you won't find in the cheap ones, their major market is aircraft where failure is not an option!
    http://earthxbatteries.com/product-c...rs-automobiles
    818R ICSCC SPM
  19. #99
    Sgt.Gator's Avatar
    Bend, Oregon
    Added Touchstone's numbers from his build thread.
    818R ICSCC SPM
  20. #100
    May 2016
    My C came in at 2008 Lbs.
  21. #101
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by SoCalK61000 View Post
    Added to the table, thanks.
    818R ICSCC SPM
  22. #102
    2310lbs
    With a VR6 Turbo, Porsche G50 and AWIC (without my 3gal water tank).
  23. #103
    Sgt.Gator's Avatar
    Bend, Oregon
    2310lbs
    818R ICSCC SPM
  24. #104
    Sgt.Gator's Avatar
    Bend, Oregon
    I added Brando's 818R. This is the weight with a dry sump, the car today no longer has the dry sump.
    Also edited the table with Hindsight's new numbers.
    818R ICSCC SPM
  25. #105
    Sgt.Gator's Avatar
    Bend, Oregon
    Updated with Wayne's build for Jonathan Preston. An 818C with flared fenders. The pics are in the Facebook 818 group, it looks awesome:
    818R ICSCC SPM
  26. #106
    Jul 2017
    The Villages Fl.
    Great looking build!!!
  27. #107
    Sgt.Gator's Avatar
    Bend, Oregon
    Added the Sgt. Gator Halo Cage Go Kart weight to the Table.
    818R ICSCC SPM
  28. #108
    Syracuse, NY
    Just put my 818R on the scales and it came in at 1,970 lbs wet with ~5 gallons of gas. build thread located here.
    MK3.1 Roadster completed 2011
  29. #109
    Sgt.Gator's Avatar
    Bend, Oregon
    Added to the table. Thanks!
    818R ICSCC SPM
  30. #110
    San Jose, CA
    I reset the ride height after it settled a bit on the HB Cruise in drive. Borrowed a set of scales today and I was closer than I hoped it would be. No fender liners yet, but full tank of gas.
    2043 total, 426 FL, 448 FR, 589 RL, 580 RR
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by svanlare View Post
    Thanks! Table updated.
    818R ICSCC SPM
  32. #112
    Sgt.Gator's Avatar
    Bend, Oregon
    Updated the table with my ready race weight.
    818R ICSCC SPM
  33. #113
    Senior Member Rob T's Avatar
    Woodruff, SC
    Gator: Came out nicely with the Halo Mod. Is it what you expected?
  34. #114
    Sgt.Gator's Avatar
    Bend, Oregon
    Initially I figured this would be about the weight. Then when the halo was done and we weighed it in Go Kart mode I thought the final weight would be 90 lbs lighter. I didn't factor in enough weight for coolant, fuel, oil, the duct work, and the DS pump - tank.
    Interestingly it only added 15 lbs mre than when Brando had it with a dry sump. I attribute that to my swapping the PC680 battery for a EarthX Lithium Ion, and removing the passenger seat.
    If anyone wants more info on EarthX batteries i'll be happy to help ou, I'm an authorized dealer. The one in my 8818R weighs 5lbs and has way more crank power than a PC 680 style battery. I'll post a vendor page in the Electrical section.
    818R ICSCC SPM
  35. #115
    Jul 2017
    The Villages Fl.
    I just weighed mine an 818S at 1940.
  36. Likes aquillen liked this post
  37. #116
    Sgt.Gator's Avatar
    Bend, Oregon
    Quote Originally Posted by redbudrr View Post
    Thanks. Added to the table.
    818R ICSCC SPM
  38. #117
    Sgt.Gator's Avatar
    Bend, Oregon
    Anyone have an update?
    818R ICSCC SPM
  39. #118
    Charm City
    I have my new wheels coming in soon so lets say by the end of January I project I should have some dry weights I could post.
    Name: biknman aka Dave
    818R
    Weight no driver: 1455lbs
    Left Front: 242lbs
    Right Front: 284lbs
    Left Rear: 429lbs
    Right Rear:500lbs
    Notes: no body, dry no fluids, no intake manifold.
    FFR 818r Instagram biknman69
    • Ernest Hemingway
  40. #119
    Nov 2015
    Saskatoon SK
    990 kg / 2,183 lbs
    Scale had a 70kg variance, wasn't 0'd out.
    Stock seats, no interior, full tank of fuel.
    There is about 50lbs extra in steel due to bumper construction to pass inspection.
  41. #120
    Chicago, IL
    OMG, this is the coolest thread ever! C'mon people, how about 1,000 thanks to Gator for making it happen!
    Executive Director
    The Community Garage
