Thanks Thanks:  12
Likes Likes:  114
Page 14 of 14 FirstFirst ... 4121314
Results 521 to 554 of 554
Thread: Toms 33
  1. #521
    May 2016
    North of sacramento Ca.
    Had car out for short ride! Been to long. All went good with intake temp 70 and engine temp at 160, need to get tuned as new engine ( custom intake cam and lower compression, and lower intake temp). Running with out fenders and side panels to check on all engine parts, can not see or get to them. Need to put head lights on to be legalIMG_8765.JPG.
  2. Likes HVACMAN, Straversi liked this post
  3. #522
    Jan 2015
    we need a video of the car running
  4. #523
    May 2016
    Tuned at 716 RWHP. Need better intercoolers.
  5. Likes j33ptj liked this post
  6. #524
    May 2016
    Made myself more work. Spun and went in ditch! Have parts on the way, is better than it looks.
    AS always i am for safety parts, high back seats, harness, and cage.IMG_8778.JPGIMG_8773.JPGIMG_8776.JPG
  7. #525
    Jan 2019
    Not gonna lie, that looks like a lot of damage.
  8. #526
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    Ouch!!! Hope the frame is still true!!
  9. #527
    Jun 2020
    SoDak
    That sucks....sorry to see this after know how much work you put into this thing.
    "Spun and went into the ditch" from slick roads, a little too much fun, or did something break?
    I just go-carted mine this weekend and I thought of every one with big engines in these things. I only have a basic 302 in mine and barely getting on it both from starting out and shifting between gears I can cut the rear tires loose so I cannot imaging how squarely (yet very fun) these things are with a ton of HP.
    Good luck, let us know how you make out.
  10. #528
    Glad you are OK. Cars can be fixed.
  11. Likes FF33rod liked this post
  12. #529
    May 2016
    Worked on car and is better than i thought. Bumper, brackets, radiator and fan gone. But custom bumper brackets and sway bar can be fixed.
    The lower control arms are gone but the upper arms look good butt i will change all the control arms out. The custom fender brackets and lower water parts are a problem. Was going to change out intercoolers, i can get to them now!
    PS rear control arms need to be changed out, will do both sides. Wheel put a small hole in my custom gas tank-- have not come up with a fix yet.IMG_8783.JPGIMG_8782.JPG
  13. #530
    May 2016
    Front is ready for new parts, fedex to bring FFR parts 12/10. So will start back together!!IMG_8786.JPG
  14. Likes RoadRacer liked this post
  15. #531
    Jun 2020
    SoDak
    Quote Originally Posted by 1932 View Post
    Glad to hear it was better than it could have been. Good luck with the rebuild
  16. #532
    May 2016
    FFR is shipping most of the parts (some on back order) i need to work on car! Making and molding parts is more fun the first time.
    Working on new intercooler, building water and air tanks.IMG_8790.JPGIMG_8791.JPG
    This is the difference inside of coolers.IMG_8793.JPGIMG_8794.JPG.
    Any ideas on fixing gas tank? Very hard to get out. Use argon to get o2 out and weld?IMG_8797.JPG this does not sound good!
  17. Likes wrp liked this post
  18. #533
    Glad you are okay
  19. #534
    Senior Member JOP33's Avatar
    Haslet, Texas
    Glad you are ok!
  20. Likes wrp liked this post
  21. #535
    May 2016
    Need end plats with 2.5 tube to be done with one new intercooler, other is half done.IMG_8799.jpgIMG_8800.jpg
    Still needing some parts for control arms.
  22. Likes wrp liked this post
  23. #536
    May 2016
    New control arms and spherical bearings in on right rear, IMG_8804.JPG The bearings had to be installed from the inside of arms, snap rings to the outside to fit ears.
    Can not put new intercoolers on till i have wheels and tiers, then build new pipes and brackets.IMG_8805.JPG
    Still waiting on some parts.
  24. #537
    May 2016
  25. Likes wrp liked this post
  26. #538
    May 2016
    Made new lower radiator tubeIMG_8813.JPG you can how it fitsIMG_8825.JPG and other parts.IMG_8818.JPG
  27. Likes wrp liked this post
  28. #539
    May 2016
    Working on fender brace and wheels and tires are on the way. Still need to mount intercoolers after i get front wheels for clearance. Had problems with hood latch hitting the top of radiator, so as i don'tIMG_8828.jpgIMG_8830.JPG need cap on radiator, it is on small tank, i cut it off.
  29. Likes wrp liked this post
  30. #540
    May 2016
  31. Likes wrp liked this post
  32. #541
    May 2016
    OK, we are all most ready for alignment. I set toe close so will be good to drive to shop.IMG_8846.JPGIMG_8850.JPGIMG_8852.JPG
  33. #542
    May 2016
  34. Likes JimLev, RoadRacer, FF33rod, j33ptj, 33fromSD, wrp liked this post
  35. #543
    Impressive!
  36. #544
    May 2016
    Got new bumper on. Different company so had to rework bracketsIMG_8861.JPGIMG_8865.JPGIMG_8866.JPG
  37. Likes JOP33 liked this post
  38. #545
    May 2016
    Had ac pump go out == lot of work to replace with ford coyote and to fit belt.IMG_8875.JPGIMG_8876.JPG
  39. Likes wrp liked this post
  40. #546
    May 2016
    Had 4-wheel alignment. 2015-17 shelby gt350R
    Car wants to duck walk under power. going back for checkup. Any thing to look for??
  41. #547
    Aug 2011
    San Jose, CA
    After a couple of close calls, I am looking at the front bumper now. Which company did you go with?
  42. #548
    May 2016
    The new one is UP, other was bob drake. I liked the bob drake better but was not available. Both are stock 33.
  43. #549
    Jun 2020
    SoDak
    You can get similar ones at Speedway Motors too.
    Jim
  44. #550
    May 2016
    Had problem with steering rack- lots of play on right side. Read in pickup forum about right side bushing working out. That was the problem with my manual rack.
    Wet cloth around rack and weld, all good.
    Metal is one inch pipe.
    The bushing was good just put back in and new part to keep in, no lose of steering movement.
  45. Likes HVACMAN, e36m3 liked this post
  46. #551
    May 2016
    Changed the wilwood front brake kit (140-12048) front pads to Hawk DTC 30 (HB645W.490) )
    I am very happy with with braking now.
  47. #552
    Aug 2011
    San Jose, CA
    I am usually a function over form guy, but I do have to say that I really like the look of the Wilwood front brakes.
  48. #553
    May 2016
    Rolled Over 6000 miles and adding.
  49. #554
    Aug 2011
    San Jose, CA
    I just broke 3,000 miles. I am doing a Calistoga lunch run this weekend just to put some miles on the hot rod.
  50. Likes JOP33, HVACMAN liked this post
