FFR's price for the kit is about right for the small quantity and the trouble it saves color matching. For the wax, you should go ahead and add it. It will not hurt anything and will make the surface cure out much nicer. You can skip it and cover with mylar as you stated, but that doesn't really gain you anything. Either way, surface prep for paint is the same.
