0
0
Wilwood Pedal Mods for Tall Drivers
I'd like to modify my Wilwood pedals for max leg room. I have the FFR supplied Wilwood pedals and the Forte hydraulic clutch kit which also comes with a Wilwood master cylinder. Wilwood tech support offers no suggestions. Is there a thread on this already? Any suggestions?
Administrator
Hi Steve,
I cut the last 1/2" off the thread protruding from the master cylinders (the part that threads into the pedal) and screw the plunger all the way into the pedal turnbuckle and that adds ~2 inches of additional leg room.
I'm looking for a pic...
EDIT: found one...
You will see that I completely removed the capture nut but with the MKIV setup - which is slightly different than this Forte's supplied MKIII pedal bracket - you can leave a nut on there to snug up to the pedal turnbuckle.
HTH,
Thanks. I had trimmed the threaded rods 1/2" but had not screwed them in all the way. That's perfect. I'll do the same when I install the clutch master cylinder. Hydraulic clutch was a late addition to the build sheet. Just arrived yesterday.
- You may not post replies
- You may not edit your posts
Forum Rules
