10
18
Brandon #9196
cgundermann
Looking good; you are really trucking along! You going to wire up your mini-starter directly or still use the remote solenoid? I went back & forth (lots of info/opinions on the forum), but in the end - went with a remote solenoid....which also served as a minibus.
I chunked the solenoid. Went from a circuit on my hood fuse box and its a dedicated 20 amp circuit running through the FFR ignition switch. It doesn't pull that much since the mini-starter has its own solenoid.
