0
0
If I understand what Hobby did was to use the kit for the Front and built special brackets for the rear. Is there any pictures of this? Does the brackets still require the GMC mounting kit? As the wheel spacers push the wheels out, is the wheel selection impacted?
Originally Posted by
UnhipPopano
The front kit is complete, no other mounting parts are required.
UnhipPopano
Depends on your wheel selection. As I said the FFR 17" wheels fit using a small 3mm spacer. I used a 5mm for extra room.
