I am installing my rear brake lines. I have a Mk IV set up for a Coyote engine, drive by wire gas pedal, which I do no have yet.
I need some help running the brake line up the tube that has the gas pedal bracket on it.
I did a quick look at some builds but did not hit on a pic that helps.
I would like to go behind the gas pedal bracket and up into the master cylinder area.
I guess I will work on the trunk drop box for now.
