As previously mentioned, I was planning on taking the hardtop off again as I need to trace down an AC issue I am having and having the top off just makes accessibility into the passenger compartment and dash much easier. I decided to make a short video of the process as well. I position the vehicle under the hoist I have, remove the Cowl Access Panels, remove the nuts on the front (5) studs, then the (5) bolts in the rear, lift off the hardtop, replace the vinyl Rear Cap and then install the Roadster Windshield. I left the access panels off so I can get to the vents on the AC. Thought it might be helpful to someone...
https://www.youtube.com/watch?v=z0Z_...7eqPuYhrofsWKM
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
