Likes Likes:  9
Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
Thread: True cost of getting a Coyote set up and running in a MK4?
    Folsom, CA
    https://performanceparts.ford.com/part/M-9000-PMCM3
    Gen3 Coyote with 6-speed via FP is $17,990
    Complete Modern Powertrain Solution for Any Ford!
    NOW AVAILABLE WITH 2018-2019 Mustang GT 5.0L 460 HP Coyote Engine!
    Tremec 6 speed manual transmission
    Complete Engine Controller and Wiring Harness (Control Pack)
    Next generation 5.0L power all in one complete powertrain kit. The crew at Ford Performance have spec'd out a kit to simplify the swap of the newest, most innovative 5.0L Coyote engine into just about any Ford vehicle. The Coyote Power Module teams the Mustang GT 460 horsepower 5.0L Coyote V8 with a state of the art Tremec 6-Speed transmission - and all the electronics and hardware to finish the installation. The engine features advances like Direct and Port Fuel Injection, Twin Independent Variable Camshaft Timing, and a lightweight plasma transferred wire arc spray aluminum engine block. Coyote Power Module simplifies both the shopping and build experience by kitting up the right parts that are matched to deliver potent performance with civilized drivability. The engine Control Pack is truly plug and play and simplifies conversions to a modern electronically fuel injected V8 high performance engine.
    2018-2019 Mustang GT 5.0L Coyote Engine - M-6007-M50C
    460 Horsepower @ 7,000 rpm
    420 lb.-ft. Torque @ 4,600 rpm
    12.0:1 Compression ratio
    Aluminum block
    Boss 302 Alternator Kit – M-8600-M50BALT
    Starter and Starter Index Plate
    Control Pack PCM and installation kit is tunable for power upgrades - M-6017-M50B
    Runs on pump gas
    Steel Quicktime Bellhousing
    Roller Pilot Bearing – M-7600-B
    Tremec 6-Speed Transmission 2.66 1st gear - M-7003-M6266
    Clutch Fork / throw-out bearing
    Clutch Kit M-7560-T46
    Billet flywheel M-6375-G46A
    Installation hardware
    Note: Engine will be fitted with dual mass flywheel installed. Included is billet flywheel, to be installed on engine before installation into vehicle
    Coyote Crate Engine Technical Reference Guide
    Click here for engine exterior dimensions
    Part Type Engine: Complete Engines Warranty Availability Not AvailableUPC Code756122012161Country of OriginMultiple Cntry Mfg. Locations
    Quote Originally Posted by toadster View Post
    Aluminum block
    Runs on pump gas
    Interesting to see they're doing a package now with the Gen 3 Coyote. For our purposes would have to add a low profile pan and hopefully a pickup is now available. Wasn't when I did mine as I described in my Coupe build thread. Then the only thing missing is that awesome Gen 3 Coyote engine cover.
    Note the price listed is the retail price from Ford Performance. Looks like street price is around $3K less.
  3. Likes toadster liked this post
  4. #43
    May 2019
    This thread is pushing me hard to the Coyote side lol!
  5. Likes toadster liked this post
  6. #44
    Folsom, CA
    yep, street price is more reasonable... and WTF was ford thinking when they designed that engine cover
  7. #45
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    Just to show that I am no Coyote hater, here is what a Coyote does better than a carbureted SBF:
    1. Gets better gas mileage.
    2. Is quieter at partial throttle. They get just as loud when they rev up.
    3. Does not need to warm up before you take off or give it some serious gas.
    4. Doesn't smell like gas. (plus or minus depending on just how much of a gear head you are)
    5. Revs higher.
    6. I would also bet that they would generally last longer for a given HP level. But that could be offset by higher rebuild costs. Opinions on this one?
    "It starts every time", "has lots of power", "power down low", "power up high", "dependable", aren't Coyote specific. My SBF fits all of those. If we are doing a why it's better list, let's keep it real.
    Idles when cold is directly related to how nasty your cam is and if you have a choke that is set correctly. A mild 347 with a choke will start right up and idle. I have 500hp, a nasty cam and no choke. I do usually have to start mine a couple times and work the throttle for several minutes when it is cold. That is actually part of what I wanted in a Cobra. It is louder than I would like, even with Flowmasters. But that idle sound will give you goosebumps.
    Coyotes are great engines. My only complaint is that they are physically huge making them harder to work on in a Cobra.
    I concur with all this. The coyote is a good engine choice, bottom line to me is do you want a modern look or old school look? Both will work well in these cars.
    Kyle
