Administrator
frankc5r
Man, it goes from 100 to 155 really fast!! I noticed you were be easy on the high speed shifts.
Really enjoyed the video.
were you able to simulate those IC temps on the dyno so you could figure out safe timing at those boost and temp levels..
On the dyno, the power pulls were shorter duration. I have the ECU set up to pull timing as the intake air temp goes up.
