Results 1 to 40 of 94
Thread: Russ Thompson Turn Signal wiring
Threaded View
    Senior Member Jdav's Avatar
    ATL GA
    I am wiring up the Russ Thompson Turn Signal and using the momentary stalk button to activate hi beam/low beam & Flash to pass with a Ron Francis harness.
    I've looked through all of the diagrams provided and others I have found, but still unsure. Especially when it comes to what wires are feeding each relay.
    Would appreciate confirmation from you guys that I am doing this right:
    Feed:
    Connect the RF gray TURN FLASHER FD wire to the Russ Thompson common larger Black wire
    Left Turn:
    Connect the RF green/yellow/green (LEFT FRONT TURN/LEFT REAR TURN/LEFT DASH IND LIGHT) bundle to the Russ Thompson Black-white wire
    Right Turn:
    Connect the RF blue/white/blue (RIGHT FRONT TURN/RIGHT REAR TURN/RIGHT DASH IND LIGHT) bundle to the Russ Thompson Black-green wire
    Flasher on/off toggle switch:
    Connect the RF pink HAZARD FLASHER wire to one spade of the switch
    Add diodes to each then join and connect the RF blue RIGHT FRT TURN and green LEFT FRT TURN wires to the other spade of the switch
    VW Relay:
    Split out and connect the RF brown HI BEAM IND wire to 56a
    Connect the RF red LOW BEAM wire to 56b
    Connect the RF blue HDLT SW>DIM SW to both 56 and 30
    Run a new wire from S to a diode, merge with a wire from 85 of Bosch relay and connect to one of the Russ Thompson smaller black wires
    Bosch Relay (i am also using a relay plug):
    Connect the other split of the RF brown HI BEAM IND wire to 30
    Merge a wire with the one coming from S of the VW relay and connect to one of the Russ Thompson smaller black wires
    Connect RF brown HIGH BEAM wire to both 86 and 87
    87a is not used
    Russ Thompson:
    Ground the other small black wire
    MK4 #9028 - Coyote - TKO600
    Delivery: 1/30/17 First Start: 7/23/17 Legal: 10/5/17 Graduated: 10/15/18
    Build thread: http://thefactoryfiveforum.com/showt...8-Build-Thread
