0
0
Inventory question
Hi Guys,
I made it through inventory tonight. I still have the body on the chassis, but managed to find almost everything without removing it. There were a couple small parts I couldn't locate on the "MKIV Mounted Components" list. I was hoping someone could point me in the right direction.
1. The 2" X 2" plastic caps, qty 4. Where are they?
2. Under the trunk hinge components FFR lists Rivnut, 1/4-20, qty 4, Are these inside the fiberglass trunk panel?
3. I didn't see the bronze bushings for the door and trunk hinges, but I assume they are assembled with the other hardware.
Serial #9158
