Dash install and Russ Thompson turn Signal
I am about to permanently install my dash and I am not sure if it is in the correct position. The top of the dash is currently about a 1/4 inch higher than the top of the 3/4 inch tube in the middle and almost a 1/2 inch above 3/4 inch tube perpendicular to the steering column. Is that correct? I also have the dash 3/16 of an inch below the corner of the 3/4 inch tube as specified in the book. The only way i can get any wiggle room is to make the whole that the Russ Thompson turn signal goes through bigger. Any help would be appreciated.
Craig
