Thread: Turn signals in ca. ?
    May 2016
    North of sacramento Ca.
    I am going to have turn signals in the stock cowl lights in the stock placement, does any have experience if that will pass inspection in CA. Will have stock tail lights.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Here is what the Vehicle Code says:
    Highlight
    CODE TEXT
    VEHICLE CODE - VEH
    DIVISION 12. EQUIPMENT OF VEHICLES [24000 - 28150] ( Division 12 enacted by Stats. 1959, Ch. 3. )
    CHAPTER 2. Lighting Equipment [24250 - 26106] ( Chapter 2 enacted by Stats. 1959, Ch. 3. )
    ARTICLE 5. Signal Lamps and Devices [24950 - 24953] ( Article 5 enacted by Stats. 1959, Ch. 3. )
    24951.
    (a) Any vehicle may be equipped with a lamp-type turn signal system capable of clearly indicating any intention to turn either to the right or to the left.
    (b) The following vehicles shall be equipped with a lamp-type turn signal system meeting the requirements of this chapter.
    (1) Motortrucks, truck tractors, buses and passenger vehicles, other than motorcycles, manufactured and first registered on or after January 1, 1958.
    (2) Trailers and semitrailers manufactured and first registered between December 31, 1957, and January 1, 1969, having a gross weight of 6,000 pounds or more.
    (3) Trailers and semitrailers 80 or more inches in width manufactured on or after January 1, 1969.
    (4) Motorcycles manufactured and first registered on or after January 1, 1973, except motor-driven cycles whose speed attainable in one mile is 30 miles per hour or less.
    The requirements of this subdivision shall not apply to special mobile equipment, or auxiliary dollies.
    (c) Turn signal lamps on vehicles manufactured on or after January 1, 1969, shall be mounted not lower than 15 inches.
    (Amended by Stats. 1975, Ch. 475.)"
    Ray
    Jan 2016
    My 33 is a 2011 SB100 special construction car that was originally built/titled in California. ( I didn't build it, it was back on East coast when I bought it ) It has the factory headlights with signals built in and stock tail lights and passed California inspection.
    Nov 2015
    Elverta, CA
    Hey Tom, what cowl setup are you going with? Are the signals going on the cowl like in front of the doors? I'm confused but suffice to say it would be up to whomever does your brake and lamp check. Dmv, CHP,and BAR never looked at any lights on mine last spring.. Seeya and give my best to your wife.
    Tom
    May 2016
    Hi tom, the turn signals will be in stock cowl lights in stock place, in front of doors.
