Side Lifts Mod
Arcflash LLC installed side lifts jacking points on the 818, the same as we have on the STI. On the 818 there is only one per side, tied into the main roll hoop to frame. Much easier to change tires and even get on the lift now.
Owner: Colonel Red Racing
eBAy Store:
http://stores.ebay.com/colonelredracing
818R ICSCC SPM
Post Thanks / Like - 1 Thanks, 2 Likes
Sgt.Gator
Ok. I've been fighting the need for an easier way to lift the car. Now I have to cut a hole in the pretty body and do a side lift point like your.
Hobby Racer
I got the idea from Retro Racing when we were at the Cascade Enduro. They use square tube and offset it. We went with simple round tube to match what we already have on the STI. Here's Retro's:
818 Side Jack Tool 2.jpg..818 Side Jack Location.jpg..818 Side Jack Tool 1.jpg
eBAy Store:
818R ICSCC SPM
Hobby Racer
Always too many good ideas here...I was also looking for ways to avoid this, but it looks like more cutting and welding for me too... =)
Is the chassis pocket exactly in-line with the center of gravity or just somewhere close/convenient? How balanced is the car when lifted there?
Santiago
I'm curious to know the answer to that as well.
Santiago
Hobby Racer
Balance doesn't matter since both wheels on the opposite side are on the ground. The car can't tilt forward or backwards. That would only come into play if you tried to use two tools and jacks at the same time on both sides of the car.
The tool works great for jacking up one side to remove wheels, or to place wood blocks under each tire/wheel on that side. Say 4" tall blocks. Then do the same on the other side. Now you can get two post lift arms under the car to get it up on the lift.
eBAy Store:
818R ICSCC SPM
Sgt.Gator
I was more interested in knowing if the front and rear lift at the same time or does it lift one or the other first. Hence, is the lift point at the balance point of the car front to rear. I'm not trying to lift both sides at once
eBAy Store:
818R ICSCC SPM
Post Thanks / Like - 2 Thanks, 3 Likes
