Using a stroked 351 Windsor and looking for recommendations on the appropriate oil pan and pickup. I was considering the Canton Street/Strip Pan Kit 70651??
I have a very nice road race oil pan that sit above the bottom if the frame.
Can you provide more details?
7qt, 7.25" deep, fully baffled with windage tray and comes with pick up and dip stick, $375
We use Canton 15-610 front sump on the 306/347 (Ford block) and 15-680 front sump on our 427 (Dart block). I can't personally verify that they work in the roadster yet, but FFR specified these for the engine a builds and I haven't heard of any customers having issues with them.
Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
Serial #9158
I put a canton 15-694 on my car. It's clearenced for a stroker
MK4 Roadster # 8548, Ford Performance X427, TKO 600, 8.8 3 Link, Paint by Jeff Miller, Suspension setup by Frank Maslowski I.E.427
I would highly recommend Gordon's pan. If you read through old threads you'll see numerous discussion on oil leaks with various pans. His pan (made by Champ Pans) fits perfect and doesn't leak a drop. It's also priced fairly.
