Results 1 to 8 of 8
Thread: Would like to build a Mk4 Roadster
    Dec 2017
    I am working on my "bucket list" and have owned a Cobra in the past. This time I would like to use as many 2018 Mustang components as I can. That includes the automatic trans. Will it fit the frame. If not why? What auto will work with 5.0 Coyote and fit the chassis? Thanks.
    Dec 2017
    Would like to hear Factory 5 techs opinions. What are limiting factors? Frame width or maybe driveshaft length.
    Colorado Springs
    Quote Originally Posted by vette40509 View Post
    I'm not a FF tech, but here's some info. Ford says they are putting out a power pack with the 6 speed auto, to include the engine, trans, ECU, and stand alone wiring harness, just like they have for the five speed. But as of last month, my local Ford dealer was not able to order it. Should be soon, though. In the mean time, you can get a stand alone wiring harness from Power By The Hour, and use a stock ECU.
    The 6 speed trans is bigger than other transmissions, mostly wider. You'll have to do some surgery to the trans tunnel to get it to fit. Only an inch here and there, nothing major. And you'll have to fab a cross member, or modify the FFR part. You'll also need to get a custom drive shaft made; also not a big deal.
    You will not be able to find a shifter specifically for this 6 speed. You can modify a lokar floor shifter to work, as you only need Drive and Manual. You might be able to modify other cable shifters to work as well. The manual shift button is available from a number of companies. But one that mounts on the shifter would require some imagination. I decided to use an electronic shifter control from Powertrain Control Solutions. https://www.powertraincontrolsolutio...utton_Shifter/ Paddle shifters are not yet available, as far as I know.
    Again, I'm not a FF tech, but I hope that helps a little.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Dec 2017
    Yes that helps alot.
    Quote Originally Posted by Bob Cowan View Post
    I think there's one available now. Any reason the one on page page 8 wouldn't work? http://lokar.com/catalog/#page=9
    Oops, double post. Didn’t catch the message about mod review.
    Colorado Springs
    It looks like it should work pretty well.
    .boB "Iron Man"
    That’s what I was hoping, thanks!
