Results 1 to 11 of 11
Thread: Rear body cross bar interference with turbo
    I have temporarily installed the rear body x bar and I have an interference with the turbo waste gate arm. Also the transmission dip stick is hitting the x bar. Has anyone else found the interference?
    A number of folks have, yes.
    I didn't have any clearance issues with the turbo though - do you have a stock turbo or aftermarket? Everyone I heard of who had the issue had an aftermarket turbo.
    I just bent my dipstick a bit to clear. Folks with turbo clearance issues mostly just modified the cross-brace. Notched it out and welded some reinforcements on there.
    I do have a stock turbo. I will have to notch the x tube and bend over the dip stick handle.
    I don't think I've seen anyone have to notch the x tube with a stock turbo.
    What motor mounts are you using? I used the cusco mounts and really like them. The mount brackets on the frame have some adjustability to them... maybe shift things around a bit? Stock up-pipe? Stock wastegate?
    All stock 2007 WRX as far as I know. The waste gate arm clears, but the push rod does not. I may adjust it with a long bar. I have adjusted the dip stick.
    Thanks for the advice.
    I have a stock 07 WRX donor on mine as well. Check my build thread for some pics of what my turbo clearance looks like. It clears by a good amount.
    http://thefactoryfiveforum.com/showt...s+build+thread
    I had clearance issues with my vf30 turbo on my ej207. http://redfogo.com/index.php/2016/12/05/update-15/
    Senior Member R.Spec's Avatar
    Portland, Oregon
    I just cut mine to fit around the turbo. Not a big deal.
    R818s | Gt35r| Forged 2.5 | Q16
    Kit Ordered 4/14 | Kit Arrived 1/15
    First Start 8/29/15 | First Drive 9/7/15
    Bowling Green, KY
    I have a VF37 and don't have clearance using CUSCO mounts. I did check out Hindsights thread and his stock turbo has a good bit more clearance than I do.
    We had the same issue with a ver 5 engine, VF28. had to section the brace out for the actuator rod.
