Thanks Thanks:  7
Likes Likes:  3
Page 4 of 4 FirstFirst ... 234
Results 121 to 131 of 131
Thread: Jdavis500 Gen 3 Coupe Build Thread
  1. #121
    My hat's off to you for tackling the bodywork on your own. I'm brave enough to try some things, but not that. Looks like you're making good progress. I believe 3/8-3/4" thick Rage Gold is maybe too much. But I'm not an expert on the subject at all. Maybe one of the Jeff's will weigh in. At the shop that did my Coupe, the guys did mention the area behind the side quarter windows where there's a pretty poor mold match they used some type of resin material for the fill. Said it would have been too thick and not strong enough with regular body filler, e.g. Rage (I don't know what brand they used). The material you're talking about is affectionately called kitty hair. Resin with strands of chopped fiberglass. I don't know if that's what my guys used. I do know there is some concern with using materials that are compatible with the vinylester resin FF makes their bodies from. Good luck and happy sanding.
  2. Likes nskaats liked this post
  3. #122
    Waiting for my 65 Coupe nskaats's Avatar
    Hebron, Ky
    Excellent progress on the body. Like Edward said, props for tackling it yourself. I've been considering doing it on my own, but I'm not a body guy by any stretch of the imagination. I can build engines, chassis, tune computers and suspension in my sleep...but body work is terrifying to me! Your posts make it seem doable.
    --Nick Skaats--
    Gen 3 Coupe #80 - LS1/T56 - SCCA Bound
    Link To Album For Updates
  4. #123
    Houston
    Quote Originally Posted by nskaats View Post
    I posted before that I had done all the body prep by myself. I used epoxy resin and FFR gelcoat and gelcoat paste exclusively. When done I had a local shade tree body guy spray it for $600 ($300 for each piece off the car).
    My body was in bad shape (worse than the pictures I have seen on the forum)....But it is not that difficult to get it right....however it takes a lot of patience time and perseverance.
    Anyway I have all three when I set my mind to it. I didn't enjoy it!
    It is not perfect but it's good enough for me and saving 10+ grand kept me going
    So, my take, it's not that difficult.
    fred
  5. #124
    Atlanta, GA
    Thanks for the encouragement nskaats and fred. Fred, you sure saved a lot of money. The red looks great! I am enjoying the ride too.
  6. #125
    You have a PM brother...da bat
  7. #126
    Atlanta, GA
    Sprayed some Slicksand yesterday.
    It was a lot of work to get one coat on the car and I haven't shot the doors yet, but things went pretty well. I used red rosin paper on the floor, covered the walls with plastic, removed all other vehicles from the garage and opened all the doors. The slicksand didn't create a lot of vapor so I didn't use a fan, but definitely will when its time to paint. There is a rhythm to it. Mix and load, spray, clean gun, repeat. The process was about 15 minutes per round and I used 16oz of Slicksand each time. I never had any issues with drying in the gun, but I could have had a bit more acetone on hand for cleaning. The main problem that I had was that I didn't organize my workspace as well as I could and I knocked some stuff over a couple of times. The car is covered pretty good. In retrospect, there were times that I did not paint in an orderly fashion. I was looking to get it covered so that I couldn't see any red gelcoat thru the primer. Next coat, I will focus more on an even coverage on the whole thing. It took a bit to get my air system right. The compressor is 475lbs which presented some challenges to get it from my street down into and thru my garage in the back of my house. Then plumbing with copper pipe which includes a water separator and a 5 stage filter. Seems good so far. We will see how limited I will be by moisture when the GA heat and humidity come soon. I would love to get the spraying done before then, but let's be realistic. I do anticipate some problems sanding the sides of the hood where the latches are. I am not sure how to get the hood into position for sanding without the latches and bolts getting in the way. I am open to suggestions.
  8. #127
    Nice progress. Again, my admiration to you for your work there. The shop that did mine left the latches with bolts in place during the rough bodywork, e.g. Rage Gold (or whatever product they used) and sanding. Had them taped off. But then removed for the rest of the time. When it came time to do the actual color, clear, and polish, they removed the hood from the hinges. Propped it up in the rough location on the body but forward enough that they could paint around the edges including the pontoons. Pictures of their entire paint process in this gallery folder FWIW: https://thefactoryfiveforum.com/album.php?albumid=1597.
  9. #128
    Atlanta, GA
    Thanks, I didn't realize you had additional pics in your album. They are helpful. Certain aspects of masking were difficult, particularly around the doors. It is hard to spray the interior surface of the body near the quarter windows(for instance) without masking a significantly concave "structure".
  10. #129
    Atlanta, GA
    Caffiene and Octane Feature
    It has been awhile since I have posted. The Daytone turned out geat. I am very happy with all the details. The paint scheme is a real eyecatcher at shows and on the street.
    My only issues are:
    1. My NRG quick release for the steering wheel has play in it when turning. It is a small amount of play, but I would rather have none. I need to work on that.
    2. I haven't found a happy place with my coilover adjustements. I get a lot of bobbing on the highway. I looked at some videos on removing the shocks and adjusting the dampers externally. I can't tell if that is what I need or if myb answer is with spring adjustemnt.
    3. My hood fitment is not perfect. It looks rgeat when I close the hood. Good gaps and allignement. It takes some effort when I close it to get everything alligned and pins engaged. I have spent hours trying to get this right, but at this point, I am willing to live with it.
    Recently, I had a small feature on Caffiene and Octane on Motortrend Network. The guy that runs the show, Skip Smith, is actually a client of mine and has been a big fan of my story. Completeing all the body work and the paint in my basement garage is a little unusual. The interview is a little short. Much was left on the cutting room floor, butit was fun to get mic'd up and be on a TV show.
    Here is the link if you are interested. I am at about 17:00.
    https://vimeo.com/869247893?share=copy
  11. Likes 460.465USMC liked this post
  12. #130
    Oct 2022
    Very cool. I watched the video
  13. #131
    Senior Member 460.465USMC's Avatar
    Aug 2019
    Spokane, WA
    Congrats on your build! I admire anyone who takes on the body/paint portion of the build. Also, very cool to be featured in the video. Great to see your finished Coupe.
    Coupe complete kit delivered: 4/22/24. Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
